Lerato
Hub 3.0 red light
My Hub 3.0 has had a red light for about 4-6 weeks now. I've done all the re-sets and run tests which keep failing.
The WiFi signal is dropping out regularly too.
The hub isn't hot and is in a well ventilated space but nothing seems to be making a difference.
Can anyone help?
Tags (1)
Serena_C
  • 2.19K
  • 91
  • 215
Re: Hub 3.0 red light
Hi @Lerato
Welcome to our Community Help Forum 🙂
Thank you for making your first post regarding the red light on your Hub, I'm sorry to hear your WiFi has been dropping. Just to double check, are you using them Hub in Modem mode?
I would like to run some diagnostics on your Hub. I shall send you a private message now to obtain the details required. Please look out for the purple envelope in the top right corner and get back to me when you can 🙂
Best wishes,
Serena
