mahfuzahmed26
Message 1 of 5
Childsafe not working with ethernet cable
Hi, I've discovered that the Childsafe feature does not work when my PC is connected to the internet via an ethernet cable. It works only when devices are connected via Wifi.
I had this problem with my old ISP, Sky and did not know that the actual problem was the ethernet connection until recently.
I've tried phoning customer support for this but they've proven useless. Can anyone advise me one here?
Many thanks.
用心棒
  • 6.88K
  • 761
  • 2.33K
Message 2 of 5
Re: Childsafe not working with ethernet cable
It is likely the DNS has been manually set for the Ethernet connection. Either:
  • use your favoured search engine to locate instruction for resetting DNS for your operating system
    or:
  • post detail of your operating system here for further help
Have I helped? Click Mark as Helpful Answer or use Kudos to say thanks
mahfuzahmed26
Message 3 of 5
Hey, thanks for the response.
So I used the 'cmd', set it to run as admin and then entered the commamd 'ipconfig /flushdns'. But this still has not done the trick sadly.
用心棒
  • 6.88K
  • 761
  • 2.33K
Message 4 of 5
Flush the device DNS cache is not what was suggested. Follow the instruction shown here up to step 2 and then make sure Obtain DNS server address automatically is selected and select OK to save the changes.
mahfuzahmed26
Message 5 of 5
Thanks, childsafe is up and running now 🙂
