Virgin Stream using VM Hub 5 in modem mode
AMCross
Obviously was working fine and then last three days must have had a firmware update
Now get your not at home message
whats the work around when using your own equipement and NOT the built in VM wifi
4 REPLIES 4
AMCross
code is CS9993
whats the work around when using your own equipement and NOT the built in VM wifiHi AMCross
What do you mean when you say you are using your own equipment and not the built in VM wifi?
VM's Stream box will only work with a VM internet connection, it doesn't work with any other ISP.
If you are using your own 3rd party router connected to the VM hub5 it should be working as long as you have set it up correctly.
Otherwise, according to the Stream error code pages <<< here >>>  it's a known issue with some services temporarily unavailable (screenshot below)
Have you used the /check-services/i  function? You can also a run a test on your equipment from there.
If nothing is showing  you could also try the automated Service Status number  0800 561 0061.  This often gives details of more local issues down to postcode level along with estimated fix dates.
Stream CS9993Stream CS9993
Dave
AMCross
as their wifi is rubbish on their hub 5 i have Ubquiti access points around my house
Stream has been working on this system for months and just stopped working
Roger_Gooner
Check that the problem isn't the Ubquiti by disconnecting it from the hub and running an Ethernet cable from the hub to the Stream's power adapter.
Hub 5, TP-Link TL-SG108S 8-port gigabit switch, 360
My Broadband Ping - Roger's VM hub 5 broadband connection
