bigwig25
  • 16
Message 1 of 5
Remote & stream box not pairing
 I have the home page picture on my tv but the remote & box will not pair.  I’ve tried - tv+rewind - tv+0, turning hub off then on and wait for 30 mins, turn tv & box off, checked batteries and tried new ones but nothing wrong with others and now I don’t know what else to do. It started playing up in the middle of Crufts last night and I don’t know the result! HELP please.
nodrogd
  • 18.74K
  • 2.23K
  • 4.84K
Message 2 of 5
Re: Remote & stream box not pairing
Firstly, you have posted in the V360 forum, which is a broadcast box (it connects directly to VMs white coaxial cable). However you are referring to a stream box.
Which do you have?
V360 master boxV360 master box
Virgin Stream IP boxVirgin Stream IP box
VM BB TV Landline. Vonage 2nd line. Freeview/Freesat HD, ASDA/Tesco PAYG Mobile. Customer since 1993
bigwig25
  • 16
Message 3 of 5
Sorry, it’s the stream ip box
  • 15.83K
  • 2.1K
  • 4.97K
Message 4 of 5
Hi @bigwig25
The following has helped some ssers pair the remote with the Switch.
Try pressing and holding the power button on the front of the stream box for about 10 seconds.
Then hopefully a message will come on the top right of the screen that says the remote is paired to the stream box.
Dave
Love, love and love, forever - Pele
bigwig25
  • 16
Message 5 of 5
Brilliant!  Thank you very much - it worked!
