Hi @scgf
Each 360 remote pairs 1 to 1 with the box, it does not use infra-red (IR). This means you can only use one remote with a box and not multiple.
The following works on the 360 so might work on the Stream.- you can use some third party remotes such as the OneForAll URC7125 - use the SimpleSet setup process and choose Ziggo manufacturer
Also the Logitech Harmony remote. You need to set them up as a "Ziggo Mediabox Next"
You can also control the 360 by using the Virgin TV Go app, so you should be able to do the same with the stream box..
EDIT - you can edit posts within 30 minutes of posting by clicking on Post Options in the top right hand corner and selecting the top option (edit)
DaveI don't work for Virgin Media.
The do's and don'ts. Keep the community welcoming for all.
Follow the house rules The Service you do for others is the rent you pay for your room here on Earth - Muhammad AliLove, love and love, forever - Pele
