Virgin Stream Box - Intermittent Signal
ToneCollis
I have recently set-up Virgin Broadband and Virgin Stream Box. When I turn on the Virgin Stream Box I get to the home screen and after 15 seconds I get a no signal error. The no signal lasts for a couple seconds and then a welcome and please wait screen appear, it then goes back on to the Virgin Stream home screen where it again goes to no signal after 15 seconds (approx).
I have been browsing this community for fixes and have tried the usual stuff (using multiple HDMI cables in different TV HDMI ports, reset my TV, reset the Stream Box, turn power on/off at mains). In the 15 seconds that I was on the home page I quickly went to settings and changed the output from 'Automatic' to the lowest video setting (576 I think) and I continued to have the same problem.
My TV is a 32" cello so it is not a very good TV. Perhaps that is the issue?
Thanks for any assistance you can provide.
1 REPLY 1
Vikki_M
Hi ToneCollis
Thank you for your post and welcome to our community.
We are aware of an activation issue with the stream box.
The team are investigating this and will have this resolved as quickly as possible.
We apologise for any inconvenience that may be caused in the meantime.
Vikki - Forum Team
