VM Stream - Confirmation Sky Sports and TNT second screen
fugio9
I made a post a few weeks ago to query if Sky Sports and TNT can be viewed on a 2nd screen if subscribed via VM Stream.
I subscribed to Sky Sports last week and TNT today so just wanted to update and hopefully help anyone looking into sports via Stream as it’s very reasonably priced.
Sky Sports can be viewed on Sky Sports app using the VM login. It does take a day or so to update on Sky’s side but it works the same way as Sky Sports via the STB packages.
TNT is available immediately in the Virgin TV Go app in the EPG and can be viewed as any other subscribed TV channel in Virgin TV Go app.
I only use Virgin TV Go app on my IPhone 14 Pro Max so can only vouch for that and it works perfectly.
1 REPLY 1
jamllew
I'm considering joining Virgin and the Stream box would be the only option for me. I know you can't record but do you have access to on demand content on TNT and/or Sky Sports?
