Lost stream box remote
Bethsam1
I have lost my stream box remote. Is there anyway to locate it? I have also looked at how I can replace it but I cannot find how to I can only find replacements for the bigger tv boxes.
6 REPLIES 6
Hi @Bethsam1
You can now order a new Stream remote online! Simply sign in to My Virgin Media to choose which TV box you have and a new remote will be delivered to you within 3-5 working days.
Try this page https://www.virginmedia.com/support/help/tv/streaming/journey/order-new-remote
Dave
The do's and don'ts.
Bethsam1
I have just tried and the response is we cannot offer you a replacement.
Hi again @Bethsam1
Sorry to see that response. You have two options then.
Call  150 from a Virgin landline or mobile, or 0345 454 1111 from any other line, option 2 (Faults
When calling Faults ignore all the options and don't press any buttons then you should be placed into a queue and an agent should pick up the phone and order the replacement remote for you.
Or wait a day or two and a member of the Forum Team should pick this up for you.
Dave
Hi @Bethsam1, thanks for reaching out to us and a warm welcome to the Virgin Media forums. 👋🏼
I'm sorry to hear about the poor experience you've had with our team for your remote.
May I ask if you've been able to sort it out since then or still require assistance?
If you require help still, let us know and we'll intervene.
Kind regards,
Ilyas.
Ilyas_Y
Hi I have been in unable to order online and unable to call as I have been working all week.
Hi Bethsam1,
You can order this yourself here once you get time, it takes around 3 to 5 days to arrive.
Paul.
