  • 5
Message 1 of 9
wifi speed
hi, i have the M50 package. i can get 50mbps hard wired into the router but the wifi is only giving out 17mbps download speed and this goes as low as 12mbps and keeps dropping out, i have followed all the instructions on the web site, i have carried out the system reboot also. i have measured this speed with four separate devices so it is not the device that is faulty. this is the speed when i am stood next to the router so distance is not an issue either.  i am guessing that the smart hub router is at fault. how do i get this changed? i cannot find a solution on the web page and dont really want to spend all night on hold on the phone to a call centre. thanks
  • 15.74K
  • 1.65K
  • 2.69K
Message 2 of 9
Re: wifi speed
If you think that you have a BB speed problem, then to check the speeds coming in to your Hub properly, and whether they match what you should be getting, you cannot rely on wifi tests, - no BB supplier guarantees those - only speeds "to" the Hub are guaranteed. So, you need to do it directly.... that's on an ethernet cable (Cat5e/6) connected to a Gb enabled computer/laptop, with up to date drivers with the Hub in modem mode. Test at speedtest.net to your nearest VM server - try 2 different browsers. If they are still low – boot the device into safe+networking mode and try again. Report back what that gets.
  • 5
Message 3 of 9
Re: wifi speed
i have 50mbps coming in, i have tested this already. the issue is the wifi speeds. thanks.
  • 15.74K
  • 1.65K
  • 2.69K
Message 4 of 9
Re: wifi speed
ok - what Hub do you have and are you connecting on the 5 or 2.4 GHz wifi band?
For example, my Macbook Air and iPhone7 both get 220mbps on my Vivid200 wifi connection - but only when I put them onto the 5GHz network. Sat in the same spot if I then flick them over to the 2.4GHz network, they max out at 70-80mbps - it's just the limitations of the technology!
  • 20.96K
  • 1.14K
  • 2.7K
Message 5 of 9
Re: wifi speed
So this isn't a speed or infrastructure issue as you get full speed when wired.
Depending on what hub you have, you could be due an upgrade to a Hub3, or you need to look into optimising your wifi yourself by way of a better router, a mesh system or running some wired AP's
  • 5
Message 6 of 9
Re: wifi speed
I have a 3.0hub. The speed is low even when I stand next to it. Thanks
  • 5
Message 7 of 9
Re: wifi speed
The hub is 3.0. Not sure how you check or change ghz WiFi band. Everything connects automatically. Thanks
  • 20.96K
  • 1.14K
  • 2.7K
Message 8 of 9
Re: wifi speed
Go into the admin pages and split the bands by renaming them to something different.
  • 5
Message 9 of 9
Re: wifi speed
tried everything but still not working. managed to contact virgin this morning who have carried out remote tests and said that the hub is faulty. they are sending out a new hub..
thanks for taking the time to respond and offer suggestions.
