gchestcam
wifi speed lost connections
I have tried the suggestions on virgin media but download and upload speeds are roughly between 9 - 13 MBPS when my package assures me I am on 200mbps !!!! Our laptops regularly lose connection which is very difficult as we are working from home using zoom and google meet (both teachers) and my daughter loses her university live lectures. I have to constantly reboot the hub to regain connection. It is very hard when we lose connection when teaching classes online.
we are considering leaving virgin broadband because of this. I have called and just get automated advice to switch off for 20 seconds etc - have done all this and no change !!!
do we need a new hub or is that it we just have to pay for a service that is not working for us unless we change to another supplier
thanks for any help
Gaynor
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Re: wifi speed lost connections
What speeds do you get at >>  SamKnows << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Then immediately after …
Login to the Hub Settings and navigate to the Connected Devices page - what is the reported 'connection speed’ for the ethernet cable connected device you used for the speed test ?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
A bit more information is required, please post the following ...
Please do this before posting the Hub Data
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
Please do not use screen shots.
Copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs onto here, if you get a yellow / straw box warning click the Post button again.
Use one post for each tab if you wish.
gchestcam
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Links aren't working - you are linking to somewhere inside your Hub.
Can you copy and paste it please.
