they now do pods - they are free on some packages - on others they will cost you £5 a month for ever
you need a hub3 or 4 for them to work - if they are free - 1gig and top range package] then they are worth a try - you need to prove a black spot using the app - if you have to pay for them then them then they are poor value and you are better buying something
____________________
Tony
