mariusmdg
  • 13
Message 1 of 8
why is broadband so slow in Enfield for so many weeks?
Anyone know what is happening in Enfield north London for the last two weeks. 100Mb service is 10-14 at best most of the day, for the last two weeks. The online status checker says Virgin are working on it, but there is no way to get an update. Anyone know when this might be resolved?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 8
Re: why is broadband so slow in Enfield for so many weeks?
What speed do you get at >> speedtest.net << with a direct connection using a Cat 5E/6 cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting your district. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Then
Can you please
Copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs onto here, if you get a yellow / straw box warning click the Post button again. Use one post for each tab if you wish. Please do not use screen grabs.
mariusmdg
  • 13
Message 3 of 8
Hi there, thanks for your response. As soon as I plugged in the network cable the download speed jumped to 110Mb using SpeedTest. Checked with wifi (no cable) and rate is now 60Mb. Networklog is:
04/11/2020 18:23:2Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/11/2020 15:46:45ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/11/2020 15:51:0criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/11/2020 15:48:0Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/11/2020 05:23:45criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/11/2020 03:46:45ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/10/2020 15:59:13criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/10/2020 15:46:45ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/10/2020 12:56:11criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/10/2020 12:49:19noticeNOTICE ATOM is restarted as part of Self Healing Mechanism;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/10/2020 20:15:40criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/10/2020 18:43:9ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 15:51:5criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/10/2020 23:50:16ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/10/2020 19:31:55criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/10/2020 11:50:16ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/10/2020 09:45:32criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/10/2020 16:57:9ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
1203000000-2.735256 qam9
2211000000-3.235256 qam10
3219000000-3.735256 qam11
4227000000-3.935256 qam12
5235000000-4.235256 qam13
6243000000-4.235256 qam14
7251000000-435256 qam15
8259000000-3.935256 qam16
9267000000-435256 qam17
10275000000-4.535256 qam18
11283000000-535256 qam19
12291000000-5.435256 qam20
13299000000-5.235256 qam21
14307000000-4.535256 qam22
15315000000-435256 qam23
16323000000-3.436256 qam24
17331000000-336256 qam25
18339000000-2.736256 qam26
19347000000-2.736256 qam27
20355000000-2.936256 qam28
21363000000-336256 qam29
22371000000-3.236256 qam30
23379000000-3.536256 qam31
24387000000-3.936256 qam32
1Locked35.78745829
2Locked35.78667669
3Locked35.712368893
4Locked35.511440897
5Locked35.515696697
6Locked35.514830525
7Locked35.58854425
8Locked35.74420465
9Locked35.75458332
10Locked35.79022316
11Locked35.58762428
12Locked35.710251362
13Locked35.713753453
14Locked35.75874353
15Locked35.73577373
16Locked36.32386295
17Locked36.32228343
18Locked36.33426329
19Locked36.31346293
20Locked36.31350301
21Locked36.32142304
22Locked36.31365300
23Locked36.32303294
24Locked36.32941982
Beth_G
  • 3.43K
  • 213
  • 345
Message 4 of 8
Hey mariusmdg,
Thanks for posting on the Community Forums.
I'm really sorry for our delayed response and to hear you've been struggling to reach your expected speeds. Have your speeds improved since posting? If your wired speeds are above 100mbs, this would mean that the issue would be wireless/device related.
Give me a shout if you need anymore help.
Beth
mariusmdg
  • 13
Message 5 of 8
 unfortunately, this is what we are back to again. really disappointing from Virgin
5.6Mbps using Broadband speed checker, and using Speedtest.net is came out as 19.8Mbps download
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 6 of 8
Are those Wi-Fi speeds ?
mariusmdg
  • 13
Message 7 of 8
sorry, to not be more specific. This issue is wifi, tested the speed with cable connected and over 100Mbps. Tested wifi and some issues. will test with other devices as this device would seem to be the issue.
Beth_G
  • 3.43K
  • 213
  • 345
Message 8 of 8
Hi mariusmdg,
Thanks for coming back.
From checking your account, we can see that there have recently been a few signal level issues showing on the account, so I have been able to arrange an engineer visit.
Please find your appointment time via your online account here, it will be shown under Orders and Appointments.
Keep us posted with how the appointment goes and we're here if you need help with anything else.
Have a great weekend and hope to hear back from you soon.
Beth
