why does speed drop from 110mb to 40mb but restarting Hub solves it ,  sneakily speed capping ?
uscool
Hi, I've had this for maybe over a year or longer on 100mb broadband , this feels like I get speed capped if use certain amount of data ? mostly I wouldnt notice when streaming unless I download something or do speedtest and see the speed
almost feels like this is done sneakily to reduce load on the network without customers noticing unless they monitor or check by doing speed tests
everytime I restart the HUB it goes back to 110mb and the cycle continues gets annoying having to restart HUB every 1-2 days , I even tested didnt restart HUB when it reduced to 40mb for few days but it never went back to 110mb untill I restarted hub
I remember years back used to have some kind of policy if you used certain amount of data was different for off peak and on peak and the speed would reduce and later would go back to normal
I dont see anything about speed capping policy now ? just feels this is done sneakily most customers probably wont notice the speeds capped for general browsing or streaming and takes load off the network
I have the HUB 5 in Modem only and use my own router Asus AX88U
its not wifi issue , I have few on wifi 6 and PC connected by ethernet cable had the same issue when I had the Hub 2
1 ACCEPTED SOLUTION
Accepted Solutions
Andrew-G
Power levels are too low downstream, probably too high upstream.  That's usually an easy fix and should improve speed and reliability.  I'll mark your post for staff to take a look and advise, they'll book a technician if it's unique to you rather than an area fault that's already being addressed.
6 REPLIES 6
Andrew-G
Sounds like a power or noise problem.  Restarting the hub makes it renegotiate all channels, and that usually gets a clean connection.  Over time that can drift off as your hub and all the other kit connected to VM's local network negotiate changes in frequency and power levels, and the slow speeds can return.
Pull up the log in page for the hub.  But don't log in, just click on the link "Check router status"  That'll bring up a window with five tabs.  Open the Downstream tab.  Select all the text (Ctrl-A if using a keyboard), copy it (Ctrl-C), then paste it (Ctrl-V) into a reply here as TEXT not screenshots.  Post that, do the same for the Upstream and Network log.  You'll get an error message when you post the Network log, just click on "post" a second time.  Then we can check for any obvious problems with power, noise or error counts.
Usually problems like this are an easy fix, but if you can make sure the hub has been running for 12-24 hours without a restart before posting the status data that increases the chance we'll spot a resolvable problem.
thanks for the quick response it has been running for over 12 hours thats for sure
1227000000-2.939QAM 25612
2211000000-2.440QAM 25610
3219000000-2.739QAM 25611
4235000000-3.140QAM 25613
5243000000-3.539QAM 25614
6251000000-439QAM 25615
7259000000-4.339QAM 25616
8267000000-3.639QAM 25617
9275000000-3.339QAM 25618
10283000000-3.239QAM 25619
11291000000-3.239QAM 25620
12299000000-3.239QAM 25621
13307000000-3.439QAM 25622
14315000000-3.639QAM 25623
15323000000-439QAM 25624
16331000000-4.339QAM 25625
17339000000-4.439QAM 25626
18347000000-4.639QAM 25627
19355000000-4.939QAM 25628
20363000000-5.139QAM 25629
21371000000-5.739QAM 25630
22379000000-6.439QAM 25631
23387000000-739QAM 25632
24395000000-6.935QAM 25633
25403000000-6.939QAM 25634
26411000000-6.938QAM 25635
27419000000-738QAM 25636
28427000000-6.938QAM 25637
29435000000-738QAM 25638
30443000000-7.239QAM 25639
31451000000-7.438QAM 25640
1Locked39109118309
2Locked4089313717
3Locked39170415566
4Locked4078215326
5Locked395424153
6Locked394623366
7Locked395245838
8Locked398378984
9Locked391312586
10Locked391552448
11Locked391935558
12Locked391073108
13Locked391122775
14Locked391293068
15Locked391113465
16Locked391233039
17Locked391972242
18Locked391492406
19Locked391312265
20Locked394166337
21Locked391403494
22Locked393643461
23Locked3910755395
24Locked351904984
25Locked39903370
26Locked38652742
27Locked385518460
28Locked38425711
29Locked38802518800
30Locked39403524
31Locked38374740
15370000051.35120QAM 642
24620000050.35120QAM 643
33940000049.55120QAM 644
43260000048.85120QAM 645
52580000048.35120QAM 646
3ATDMA0000
4ATDMA0000
5ATDMA0000
23-06-2022 12:20:37noticeCM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
23-06-2022 12:18:45noticeCM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
23-06-2022 12:12:33noticeCM-STATUS message sent. Event Type Code: 22; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
23-06-2022 12:10:44noticeCM-STATUS message sent. Event Type Code: 20; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
23-06-2022 12:05:37noticeCM-STATUS message sent. Event Type Code: 22; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
23-06-2022 12:01:49noticeCM-STATUS message sent. Event Type Code: 20; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
23-06-2022 11:56:46noticeCM-STATUS message sent. Event Type Code: 22; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
23-06-2022 11:52:05noticeCM-STATUS message sent. Event Type Code: 20; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
23-06-2022 11:50:42noticeCM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
23-06-2022 11:48:46noticeCM-STATUS message sent. Event Type Code: 22; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
23-06-2022 11:44:00noticeCM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
23-06-2022 11:43:58noticeCM-STATUS message sent. Event Type Code: 20; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
23-06-2022 11:11:02noticeCM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
23-06-2022 11:06:37noticeCM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
23-06-2022 10:18:05noticeCM-STATUS message sent. Event Type Code: 22; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
23-06-2022 10:15:24noticeCM-STATUS message sent. Event Type Code: 20; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
23-06-2022 09:55:36noticeCM-STATUS message sent. Event Type Code: 22; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
23-06-2022 09:52:25noticeCM-STATUS message sent. Event Type Code: 20; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
23-06-2022 09:51:32noticeCM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
23-06-2022 09:49:41noticeCM-STATUS message sent. Event Type Code: 22; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
23-06-2022 09:47:30noticeCM-STATUS message sent. Event Type Code: 20; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
23-06-2022 09:46:37noticeCM-STATUS message sent. Event Type Code: 22; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
23-06-2022 09:44:30noticeCM-STATUS message sent. Event Type Code: 20; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
23-06-2022 09:43:16noticeCM-STATUS message sent. Event Type Code: 22; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
23-06-2022 09:39:53noticeCM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
23-06-2022 09:39:52noticeCM-STATUS message sent. Event Type Code: 20; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
23-06-2022 09:31:02noticeCM-STATUS message sent. Event Type Code: 22; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
23-06-2022 09:25:30noticeCM-STATUS message sent. Event Type Code: 20; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
23-06-2022 08:54:10noticeCM-STATUS message sent. Event Type Code: 22; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
23-06-2022 08:52:06noticeCM-STATUS message sent. Event Type Code: 20; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
23-06-2022 08:50:25noticeCM-STATUS message sent. Event Type Code: 22; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
23-06-2022 08:48:29noticeCM-STATUS message sent. Event Type Code: 20; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Andrew-G
Pretty sure sometimes it's fine for around week or maybe longer other times it can happen every few days
I did notice month or so back the internet would stop working around 12am-1am it happened few times and around the same time each time no issues during the day
It hasn't happened past few weeks
Hey Uscool,
Thanks for posting here with your issue, I'm sorry to see you've been facing some issues with your broadband speeds. In order to provide further assistance with this I will send you a PM now.
Please check the top-right corner of our forum and you should see a purple envelope. Click this and you'll see my message.
Adri
Hi @uscool
I can see you've already been in contact with my colleague via PM who's booked you a visit 🙂 let us know how the tech visit goes.
Best,
John_GS
