jameshill
  • 10
Message 1 of 8
very slow upload speed
I've got a 100mb package through a hub 3
My machine is connected by ethernet to the hub.
I'm currently getting an upload speed of about 1mb, but thats intermittent which is making it nearly impossible to work remotely.
Any help would be appreciated.
 James
Tags (1)
conman33158
  • 726
  • 66
  • 95
Superfast
Message 2 of 8
Re: very slow upload speed
Can you please upload your router stats
Type 192.168.0.1 or (192.168.100.1 if you have your Hub in Modem mode) into your address bar at the top of your browser
For Hubs 2 & 3 - DO NOT LOG IN, just click “Check Router Status”
For Hub 4 - When the page appears LOG IN then click on:
Advanced Settings > Tools > Network Status.
Please copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs, if you get a yellow warning just click the Post button again. You can use more than one post for each item if needed.
If you get a warning when you hit “Post” just hit “Post” again and it should work ok!
Please do not use screenshots
Also can you please setup a Broadband Quality Monitor (BQM) at thinkbroadband.com. Just click on Create a new monitor.
Post a 'Live Link' to your BQM on here asap.
Under your graph you just created Click (Share Live Graph) then click generate.
Copy the text in the Direct Link box and paste it on here
jameshill
  • 10
Message 3 of 8
14190000009.137256 qam32
22030000009.538256 qam9
32110000009.338256 qam10
4219000000940256 qam11
52270000008.840256 qam12
62350000008.840256 qam13
72430000008.540256 qam14
82510000008.440256 qam15
92590000008.440256 qam16
102670000008.538256 qam17
11275000000940256 qam18
122830000009.540256 qam19
132910000009.940256 qam20
142990000001038256 qam21
153070000009.940256 qam22
163150000009.638256 qam23
173230000009.638256 qam24
183630000009.838256 qam25
193710000009.638256 qam26
203790000009.538256 qam27
213870000009.438256 qam28
223950000009.437256 qam29
234030000009.137256 qam30
24411000000937256 qam31
1Locked37.6600
2Locked38.9250
3Locked38.9290
4Locked40.3230
5Locked40.3270
6Locked40.3400
7Locked40.3330
8Locked40.3350
9Locked40.3190
10Locked38.9350
11Locked40.3260
12Locked40.3180
13Locked40.9210
14Locked38.9340
15Locked40.3390
16Locked38.9410
17Locked38.9270
18Locked38.6350
19Locked38.6390
20Locked38.9380
21Locked38.9470
22Locked37.6620
23Locked37.3630
24Locked37.3650
jameshill
  • 10
Message 4 of 8
14619998838.5512064 qam3
23940000037512064 qam4
35370000438.5512064 qam2
46030001440512064 qam1
1ATDMA0020
2ATDMA0010
3ATDMA0000
4ATDMA0010
jameshill
  • 10
Message 5 of 8
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
iyewrkldJKDHSUBsgvca69834
SFID19258
Max Traffic Rate117000047
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID19257
Max Traffic Rate10500047
Max Traffic Burst16320
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling TypeBestEffort
conman33158
  • 726
  • 66
  • 95
Superfast
Message 6 of 8
Your router stats look fine, the power levels are a bit high on the download streams but still within spec. We will see if the BQM shows anything once you post it.
In the meantime, what speed do you get on https://speedtest.samknows.com/ with direct wired connection from PC/Laptop to router using a Cat 5e cable or better with a 1Gbps capable Ethernet network card?
  1. Make sure the cable is Cat 5e or better
  2. Make sure your PC/laptop has a 1Gbps or better network card
  3. Make sure Hub is in router mode
  4. Disconnect all other Ethernet cables when running the test
jameshill
  • 10
Message 7 of 8
I think it might be down to the latency?
I'm getting around 15ms.
Do you think this is the problem why my remote connection keeps dropping out?
conman33158
  • 726
  • 66
  • 95
Superfast
Message 8 of 8
Not sure without the BQM I asked to to create. 15ms latency is quite good so nothing to worry about there 🙂
