Bob_D1
very slow speed
New service and Hub 3 installed a week ago
expected speed of 200 Mb
I ran the test as instructed here
Broadband Speed Check - Virgin Media Community - 3459473
Here's the results
PING ms 11
DOWNLOAD Mbps 23.46
UPLOAD Mbps 16.40
I then navigated to this address -  Use your browser to navigate to 192.168.0.1
I'm now looking for my hub stats as per
"Hub 3 users will find “Check Router Status” below the log in screen to access this information"
I cannot see “Check Router Status” anywhere on this page. I have taken a screenshot but it appears I cannot post it with this question.
Can someone help. This was supposed to be an upgrade but our speeds are now unbearable slow.
thank you
Anonymous
Not applicable
Re: very slow speed
Here's the results
PING ms 11
DOWNLOAD Mbps 23.46
UPLOAD Mbps 16.40
thank you
If it's not on the main login page login to the HUB and access the same options through 'Advanced settings / Tools / Network status'.
Bob_D1
Re: very slow speed
thank you - here's the information
118675000012.340256 qam7
21947500001240256 qam8
320275000011.840256 qam9
421075000011.540256 qam10
521875000011.540256 qam11
622675000011.140256 qam12
72347500001140256 qam13
824275000010.640256 qam14
925075000010.540256 qam15
1025875000010.440256 qam16
1126675000010.540256 qam17
1227475000010.540256 qam18
1328275000010.640256 qam19
1429075000010.640256 qam20
152987500001140256 qam21
1630675000010.540256 qam22
1731475000010.440256 qam23
1832275000010.140256 qam24
1940275000010.340256 qam25
2041075000010.940256 qam26
2141875000010.940256 qam27
2242675000010.640256 qam28
2343475000010.140256 qam29
244427500001040256 qam30
1Locked40.316388
2Locked40.917114
3Locked40.318253
4Locked40.311771
5Locked40.37979
6Locked40.36835
7Locked40.9400
8Locked40.3190
9Locked40.39836
10Locked40.99749
11Locked40.38250
12Locked40.97321
13Locked40.37569
14Locked40.38576
15Locked40.39731
16Locked40.9590
17Locked40.39812
18Locked40.37313
19Locked40.380
20Locked40.360
21Locked40.950
22Locked40.970
23Locked40.970
24Locked40.970
15370004545512064 qam2
23940018045512064 qam4
34620003045.3512064 qam3
46030005842.8512064 qam1
3ATDMA0000
4ATDMA0000
Bob_D1
Re: very slow speed
and Router Status
22/11/2020 12:17:50noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/11/2020 11:59:12Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/11/2020 21:13:25noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/11/2020 16:48:42noticeNOTICE ATOM is restarted as part of Self Healing Mechanism;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/11/2020 07:29:44criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/11/2020 22:19:59ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:36criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/11/2020 21:17:45ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/11/2020 20:49:6noticeSW download Successful - Via Config file
14/11/2020 20:47:9noticeSW Download INIT - Via Config file
01/01/1970 00:01:37criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: very slow speed
Your Downstream Power Levels are too high.
This will need an engineer to put right.
You can either call in (08:00 is the best time) or wait on here for a few days (6 to 7 days average) until one of the VM Forum Staff comes along.
Bob_D1
Re: very slow speed
Thank you
I will call
