huseyinbashan
very slow internet speed
I use 100 Mbps Virgin media internet. But nowadays speed test shows 7 Mbps. (device is connected to wi-fi). I reset and restarted the Hub. But the result has not changed.
https://www.speedtest.net/result/10494374462.png
Customer service does not answer my phone calls and I waited more an hour  in call to talk someone from virgin media . But nobody answered my call.
Tags (1)
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Re: very slow internet speed
Which Hub do you have ?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Can you please
huseyinbashan
I am sharing my broadband live link:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/4d45c6d9dfcdff6a1a816518586002633f...
https://www.thinkbroadband.com/broadband/monitoring/quality/share/4d45c6d9dfcdff6a1a816518586002633f43aff7
huseyinbashan
I use Hub 3
Here is the config:
Cable Modem Status
Item Status Comments
139000000
Locked
Ranged Upstream Channel (Hz)
39400000
Locked
Provisioning State
Online
1 139000000 4 35 256 qam 1
2 147000000 3 35 256 qam 2
3 155000000 3.4 35 256 qam 3
4 163000000 3 35 256 qam 4
5 171000000 2.7 35 256 qam 5
6 179000000 2.7 35 256 qam 6
7 187000000 3 35 256 qam 7
8 195000000 2.5 35 256 qam 8
9 203000000 1.5 35 256 qam 9
10 211000000 1 35 256 qam 10
11 219000000 1.5 36 256 qam 11
12 227000000 1 35 256 qam 12
13 235000000 0.5 35 256 qam 13
14 243000000 -0.4 35 256 qam 14
15 251000000 0 36 256 qam 15
16 259000000 1.2 36 256 qam 16
17 267000000 1.7 36 256 qam 17
18 275000000 2 36 256 qam 18
19 283000000 2.9 36 256 qam 19
20 291000000 3.2 36 256 qam 20
21 299000000 3.2 36 256 qam 21
22 307000000 3 36 256 qam 22
23 315000000 3.5 36 256 qam 23
24 323000000 3.5 36 256 qam 24
1 Locked 35.5 1221 0
2 Locked 35.5 1347 0
3 Locked 35.7 404 0
4 Locked 35.5 751 0
5 Locked 35.5 1769 0
6 Locked 35.5 1927 0
7 Locked 35.7 216 0
8 Locked 35.7 223 0
9 Locked 35.5 529 0
10 Locked 35.5 973 0
11 Locked 36.3 65 0
12 Locked 35.5 252 0
13 Locked 35.7 137 0
14 Locked 35.7 103 0
15 Locked 36.3 115 0
16 Locked 36.3 45 0
17 Locked 36.6 17 0
18 Locked 36.6 20 0
19 Locked 36.3 19 0
20 Locked 36.6 16 0
21 Locked 36.6 16 0
22 Locked 36.6 22 0
23 Locked 36.6 11 0
24 Locked 36.6 6 0
1 39400000 44 5120 64 qam 4
2 46200000 44.3 5120 64 qam 3
3 32600000 42.8 5120 64 qam 5
4 25799980 41.8 5120 32 qam 6
1 ATDMA 0 0 0 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 0 0
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt057-b.cm
SFID 357030
Max Traffic Rate 117000047
Max Traffic Burst 42600
Min Traffic Rate 0
Primary Upstream Service Flow
SFID 357029
Max Traffic Rate 10500047
Max Traffic Burst 16320
Min Traffic Rate 0
Max Concatenated Burst 16320
Scheduling Type BestEffort
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Your Hub data and BQM look OK.
What speeds do you get at >> speedtest.net << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
