jason840
  • 7
very low speeds
for about 24 hours now my connection has been stuck at 1mbps down when tested both wired and wirelessly, yesterday while trying to solve the issue i put the router in modem mode and changed it back again and for a minute or so afterwards i was receiving my proper speeds (100mbps) before it dropped again. i've done everything that's been suggested, including resetting the router to factory settings but nothing has helped.
here's my logs:
483000000
Locked
Ranged Upstream Channel (Hz)
46199876
Locked
Provisioning State
Online
1483000000-2.938256 qam30
2187000000-1.438256 qam7
3195000000-1.538256 qam8
4203000000-1.738256 qam9
5211000000-1.938256 qam10
6219000000-238256 qam11
7227000000-238256 qam12
8235000000-238256 qam13
9243000000-2.238256 qam14
10251000000-2.238256 qam15
11259000000-2.538256 qam16
12267000000-2.538256 qam17
13275000000-2.738256 qam18
14283000000-2.538256 qam19
15291000000-2.938256 qam20
16299000000-2.738256 qam21
17307000000-2.938256 qam22
18315000000-3.238256 qam23
19323000000-338256 qam24
20443000000-2.738256 qam25
21451000000-2.738256 qam26
22459000000-2.738256 qam27
23467000000-2.738256 qam28
24475000000-338256 qam29
1Locked38.650
2Locked38.960
3Locked38.950
4Locked38.660
5Locked38.650
6Locked38.960
7Locked38.940
8Locked38.950
9Locked38.950
10Locked38.950
11Locked38.900
12Locked38.950
13Locked38.640
14Locked38.960
15Locked38.660
16Locked38.950
17Locked38.950
18Locked38.900
19Locked38.900
20Locked38.660
21Locked38.960
22Locked38.960
23Locked38.950
24Locked38.940
continued below:
jason840
  • 7
Re: very low speeds
1461998763.718512064 qam11
2257999693.725512064 qam14
3326000193.725512064 qam13
4394000023.725512064 qam12
3ATDMA0000
4ATDMA000
0
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
;fg87dsfd;kfoA,.iyewrkldJKDHSUBsg
SFID22935
Max Traffic Rate117000047
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID10808
Max Traffic Rate10500047
Max Traffic Burst16320
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling TypeBestEffort
13/05/2020 02:36:5noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/05/2020 21:55:42criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/05/2020 21:09:28noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/05/2020 21:09:11Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/05/2020 20:59:55noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/05/2020 20:24:20criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/05/2020 19:07:9Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/05/2020 19:07:8Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/05/2020 19:07:3Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/05/2020 19:07:3criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/05/2020 19:07:2Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/05/2020 19:07:2criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/05/2020 12:32:33ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/05/2020 10:10:46criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/05/2020 05:59:14ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/05/2020 17:49:59criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/05/2020 16:52:36ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/05/2020 06:17:37criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/05/2020 16:40:19noticeTouchstone SW Upgrade Reboot Delayed due to Call in Progress;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
jason840
  • 7
Re: very low speeds
when i reset the router i get the speeds i'm paying for but only for a minute or so and it's right back down again. this is so frustrating. woUvzfM.png
David_Bn
  • 4.89K
  • 225
  • 401
Re: very low speeds
Good Morning Jason.
Thanks for your post on our Community Forums and a very warm welcome to you!
Sorry to see that you're experiencing some very slow speeds on your broadband connection over Wi-Fi
Can you please run a speed test on the hub, with the hub in modem mode, this will allows us to see what speed your getting into the property. Can you also tell us what speed your subscribing to?
Kindest regards,
David_BN
