helenmarie33
Just joined
upload speed under 0.1
Been having wifi speed issues, under 5mbps, and even hard wire to router connections cutting out. Did a hard reset, wifi download now good 100mbps but upload under 0.1 mbps, any help appreciated
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Re: upload speed under 0.1
You need to measure the speeds using an ethernet cable connected device, Wi-Fi isn't stable enough for accurate results.
