zanchelina
  • 6
Message 1 of 11
upload speed problems
Hello, over past few month i have problems with my upload speed, as i have someone in a house who does streaming it is a big issue. upload speed constantly goes from 30 mb to 1-3mb max with speed like that it is impossible to stream.
377757354e837add5ad060af0f3c89753de135c4-16-05-2021.png377757354e837add5ad060af0f3c89753de135c4-15-05-2021.png
13310000007.340256 qam25
21870000006.540256 qam7
31950000006.540256 qam8
42030000006.540256 qam9
52110000005.540256 qam10
62190000004.940256 qam11
72270000005.338256 qam12
82350000005.840256 qam13
9243000000640256 qam14
102510000006.340256 qam15
112590000006.540256 qam16
122670000006.640256 qam17
132750000006.640256 qam18
14283000000740256 qam19
152910000007.440256 qam20
162990000008.140256 qam21
173070000008.640256 qam22
183150000009.340256 qam23
193230000008.540256 qam24
203710000007.940256 qam26
21379000000840256 qam27
223870000007.940256 qam28
23395000000840256 qam29
244030000008.340256 qam30
1Locked40.370
2Locked40.350
3Locked40.9180
4Locked40.350
5Locked40.9120
6Locked40.370
7Locked38.940
8Locked40.360
9Locked40.360
10Locked40.300
11Locked40.960
12Locked40.350
13Locked40.350
14Locked40.960
15Locked40.950
16Locked40.3200
17Locked40.350
18Locked40.960
19Locked40.340
20Locked40.300
21Locked40.340
22Locked40.950
23Locked40.350
24Locked40.94
0
14620001746512064 qam1
22580002446512064 qam4
33260004646512064 qam3
43940000446512064 qam2
zanchelina
  • 6
Message 2 of 11
Re: upload speed problems
13/05/2021 12:41:29criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/05/2021 11:23:17noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/05/2021 11:23:17ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/05/2021 01:38:49criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/05/2021 17:05:7noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/05/2021 17:05:7ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/05/2021 17:43:9noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/05/2021 17:42:25Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/05/2021 17:12:6noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/05/2021 17:08:9Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/05/2021 20:02:42criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/05/2021 16:41:29noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/05/2021 16:41:29ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/05/2021 14:08:35criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/05/2021 07:40:46Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/05/2021 10:50:48criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/05/2021 09:04:46Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/05/2021 14:51:2criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/05/2021 04:41:29noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/05/2021 04:41:29ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
zanchelina
  • 6
Message 3 of 11
377757354e837add5ad060af0f3c89753de135c4-15-05-2021.png377757354e837add5ad060af0f3c89753de135c4-16-05-2021.png
risc19
  • 849
  • 27
  • 253
Well-informed
Message 4 of 11
Hub stats look good.
BQM looks ok ish.
Can you paste the rest of the upstream hub stats, the but that says timeouts.
Did you do a reboot recently?
Is that the red lines on the BQM?
My Broadband Ping - Virgin Lagfest Modem Mode
zanchelina
  • 6
Message 5 of 11
no i haven't rebooted my modem in this charts.
im guessing if my charts looks okish i'm better off to change internet providers.
3ATDMA0000
4ATDMA0000
risc19
  • 849
  • 27
  • 253
Well-informed
Message 6 of 11
Well it's kind odd not having any upstream timeouts, given virgins quality.
Virgin will be along at some point to help.
Were those tests via wifi or an ethernet cable?
You may as well give it a reboot now before they ask you to do so.
Turn it off wait a few minutes and power it up again.
zanchelina
  • 6
Message 7 of 11
ethernet cable,we never really had any issues with download speed,its just upload speed i'm trying to fix, and its on multiple times on a day when dropping from 30 mbps to like 4mbps we had an engineer around couple month ago he just changed new modem and checked cables and didn't find any issue.
anyways Thanks for your help 🙂
risc19
  • 849
  • 27
  • 253
Well-informed
Message 8 of 11
It's probably a network fault of some kind.
The only other thing I can suggest is trying a different cable for a speed test.
That and a reboot.
David_Bn
  • 7.11K
  • 310
  • 586
Message 9 of 11
Good Afternoon zanchelina,
Thanks for your post on our Community Forums and a very warm welcome to you!
Can you please advise me what upload speed your able to get with the hub in modem mode and connected via a Cat 6 Ethernet cable?
I've not been able to find your account, can you please confirm if you've checked the service status checker to see if any outages appear in your local area?
Kindest regards,
David_Bn
zanchelina
  • 6
Message 10 of 11
Hello,
at the moment my upload speed is this,right now.jpg which is very low again. this is been tested via hub mode and Ethernet cable. i have checked service status it is always showing that there is no issues. upload speed was dropping numerous times this week different times, morning , afternoon and evening evening like right now i have only 4.27Mbps upload where it should be around 30mbps.
Account number [DELETED] Area reference30
this need sorting out because it is been like this for a year, i dont feel like i should pay 55£ for M350 Fibre Broadband where it should be 36mbps and im not even getting half of it.
[MOD EDIT: Personal and private information has been removed from this post.]
