matthew999
  • 19
Message 1 of 31
upload speed fluctuation
Hello,
i have M350 fibre broadband, which is supposed to give me 350 down and 35 upload. I am hardwired to the router via cat 6 and on a Hub4.
Is it normal for my upload to drop to as low as 10Mbps during the day. Obviously its much higher frist thing in the morning and the middle of the night, hitting closer to above advertised speeds.
Was pretty consistant for the first few months of ownership, Only really noticed this fluctiation since the free upgrade to the hub 4.
any pointers would be greatly appreciated
thanks
matt
Anonymous
Not applicable
Message 2 of 31
Re: upload speed fluctuation
@matthew999 wrote:
Hello,
thanks
matt
Could you access your router using http://192.168.0.1/ or http://192.168.100.1 for modem mode . You shouldn't need log in, select the 'Check Router Status' option and paste your 'Downstream', 'Upstream', and 'Network Log' tabs? Please copy/paste this data as text, split between multiple posts (Sometimes you have to click 'Post' twice due to an error message).
Could you please create a BQM (Broadband Quality Monitor) here, and post the live link?
matthew999
  • 19
Message 3 of 31
When i click check router status i get a spinning dial, then it is blank. can i access this information once logged in?
this is what it looks like
thanks
matt
Anonymous
Not applicable
Message 4 of 31
@matthew999 wrote:
thanks
matt
Ah sorry HUB 4. There is a bug and you must log in and access 'Advanced Settings / Tools / Network Status' to get the stats I asked for!
matthew999
  • 19
Message 5 of 31
matthew999
  • 19
Message 6 of 31
3.0 Downstream channels
253310000007.30000338.983261QAM25625
41630000009.69999738.605377QAM2564
51710000009.09999838.605377QAM2565
61790000008.80000338.605377QAM2566
71870000008.50000038.983261QAM2567
81950000008.40000238.605377QAM2568
92030000008.09999838.605377QAM2569
102110000007.69999738.983261QAM25610
112190000007.30000338.983261QAM25611
122270000007.19999738.605377QAM25612
132350000007.00000038.605377QAM25613
142430000006.90000238.605377QAM25614
152510000006.80000338.605377QAM25615
162590000006.80000338.605377QAM25616
172670000006.40000237.636276QAM25617
182750000006.69999738.605377QAM25618
192830000006.59999838.983261QAM25619
202910000005.59999838.605377QAM25620
212990000005.19999738.605377QAM25621
223070000005.80000338.605377QAM25622
233150000005.80000338.605377QAM25623
243230000006.30000338.605377QAM25624
263390000007.80000338.605377QAM25626
273470000007.50000038.605377QAM25627
283550000007.50000038.605377QAM25628
293630000007.69999738.605377QAM25629
303710000006.90000238.605377QAM25630
313790000006.50000038.605377QAM25631
323870000007.09999838.605377QAM25632
333950000006.90000238.605377QAM25633
344030000006.30000338.983261QAM25634
25Locked000
4Locked31215501400
5Locked36510971300
6Locked36639597400
7Locked32450892000
8Locked37509257000
9Locked42256071000
10Locked11943336000
11Locked10571368300
12Locked10049836500
13Locked12058902700
14Locked11767063600
15Locked10724021000
16Locked10453060300
17Locked11407393800
18Locked11835861100
19Locked358979419300
20Locked6843316700
21Locked11860342200
22Locked12354608000
23Locked286731242000
24Locked18639762500
26Locked18657548200
27Locked16580376900
28Locked16476062600
29Locked18447439900
30Locked18463906000
31Locked213711270800
32Locked16024306400
33Locked19239467100
34Locked31150119200
3.1 Downstream channelsChannel Channel Width (MHz) FFT Type Number of Active Subcarriers Modulation (Active Profile) First Active Subcarrier (Hz)
35964K1880QAM4096759
3.1 Downstream channelsChannel ID Lock Status RxMER Data (dB) PLC Power (dBmV) Correcteds (Active Profile) Uncorrectables (Active Profile)
35Locked 1.973006238832
matthew999
  • 19
Message 7 of 31
3.0 Upstream channelsChannel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
15370000047.5205995120 KSym/sec64QAM2
24620000046.7705995120 KSym/sec64QAM3
33940000047.0205995120 KSym/sec64QAM4
43260000046.5205995120 KSym/sec64QAM5
3.0 Upstream channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
1US_TYPE_STDMA0070
2US_TYPE_STDMA0070
3US_TYPE_STDMA0070
4US_TYPE_STDMA0070
matthew999
  • 19
Message 8 of 31
Network LogTime Priority Description
Thu 01/01/1970 00:01:193No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 16/10/2020 18:49:235MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 16/10/2020 18:52:326SW Download INIT - Via Config file cmreg-vmdg640-bbt062-b.cm
Fri 16/10/2020 18:53:466SW download Successful - Via Config file
Fri 16/10/2020 18:56:175MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 16/10/2020 19:22:364DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 17/10/2020 13:46:033No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 20/10/2020 08:20:534DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 22/10/2020 04:07:566CM-STATUS message sent. Event Type Code: 23; Chan ID: 35; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 22/10/2020 23:51:163No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 24/10/2020 00:50:524DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 25/10/2020 20:01:383No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 27/10/2020 12:50:524DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 27/10/2020 14:03:503No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 31/10/2020 00:50:524DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 05/11/2020 05:07:576CM-STATUS message sent. Event Type Code: 23; Chan ID: 35; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 07/11/2020 00:50:524DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 07/11/2020 14:01:483No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 10/11/2020 12:50:534DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 11/11/2020 07:29:183No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 12/11/2020 05:26:586CM-STATUS message sent. Event Type Code: 23; Chan ID: 35; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 12/11/2020 12:12:263No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 14/11/2020 00:50:534DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 15/11/2020 13:15:443No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 17/11/2020 11:31:375MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 01/01/1970 00:01:213No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 17/11/2020 11:41:015MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 17/11/2020 11:41:093No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 17/11/2020 11:44:355MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 17/11/2020 12:57:433No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Anonymous
Not applicable
Message 9 of 31
1US_TYPE_STDMA0070
2US_TYPE_STDMA0070
3US_TYPE_STDMA0070
4US_TYPE_STDMA0070
The current upstream stats look ok, however the timeouts, hlighlighted, are a concern.
We'll need to let the BQM run for a while to see the quality of your line.
matthew999
  • 19
Message 10 of 31
Hi Carl
Did you have a chance to look at my BQM stats
thanks
Matt
