monty9845
  • 5
Message 1 of 11
upload speed being throttled?
It seems I am not the only one seeing upload speeds reducing from the usual 10 Mbps to below 1 Mbps (often well below) between 9am and 6pm.  For me personally this has been going on for about a week.  Is Virgin deliberately throttling upload speeds in my area,  is it a fault on their network or is it just too many people on video calls?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 2 of 11
Re: upload speed being throttled?
Please do this before the Hub Data
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 3 of 11
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
Copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs onto here, if you get a yellow / straw box warning click the Post button again.
Use one post for each tab if you wish.
Please do not use screen shots.
monty9845
  • 5
Message 4 of 11
My BQM
monty9845
  • 5
Message 5 of 11
12027500002.238256 qam9
22107500002.738256 qam10
32187500002.538256 qam11
42267500002.538256 qam12
52347500002.538256 qam13
62427500002.538256 qam14
72507500002.538256 qam15
82587500002.438256 qam16
92667500002.538256 qam17
102747500002.238256 qam18
112827500002.538256 qam19
122907500002.538256 qam20
132987500002.538256 qam21
143067500002.538256 qam22
153147500002.438256 qam23
163227500002.438256 qam24
173307500002.538256 qam25
183707500001.738256 qam26
193787500001.538256 qam27
203867500001.238256 qam28
21394750000138256 qam29
22402750000138256 qam30
23410750000138256 qam31
244187500000.738256 qam32
1Locked38.9120
2Locked38.6100
3Locked38.9170
4Locked38.6190
5Locked38.970
6Locked38.6170
7Locked38.6140
8Locked38.6140
9Locked38.980
10Locked38.9250
11Locked38.6150
12Locked38.9160
13Locked38.6270
14Locked38.9140
15Locked38.9280
16Locked38.6180
17Locked38.6150
18Locked38.670
19Locked38.6170
20Locked38.9240
21Locked38.6200
22Locked38.670
23Locked38.6140
24Locked38.6100
13940003438.8512064 qam4
24620000039.3512064 qam3
35369992240512064 qam2
46029998941.3512064 qam1
3ATDMA0000
4ATDMA0000
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt057-b.cm
SFID37996
Max Traffic Rate117000047
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID37995
Max Traffic Rate10500047
Max Traffic Burst16320
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling TypeBestEffort
monty9845
  • 5
Message 6 of 11
13/01/2021 12:08:44noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/01/2021 16:49:0criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/01/2021 12:11:15ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/01/2021 02:33:35noticeSW download Successful - Via NMS
09/01/2021 02:31:10noticeSW Download INIT - Via NMS
08/01/2021 17:06:45noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/01/2021 17:06:18Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/01/2021 21:46:53ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/01/2021 11:39:27criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/01/2021 09:46:52ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/12/2020 19:20:49criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/12/2020 21:46:52ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/12/2020 19:26:39criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/12/2020 09:46:52ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/12/2020 04:59:59criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/12/2020 21:46:52ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/12/2020 03:49:13criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/12/2020 21:46:52ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/12/2020 08:03:47criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/12/2020 09:46:52ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 7 of 11
Your >> BQM << is showing typical signs of over utilisation.
A good friend of the forums @Andruser has commented on the forum about similar problems to yours ...
https://community.virginmedia.com/t5/Speed/Advice-on-stats-etc/td-p/4555347/page/2
https://community.virginmedia.com/t5/Networking-and-WiFi/Poor-BQM/m-p/4557860#M365466
Andrew-G
  • 8.14K
  • 1.36K
  • 3.68K
Message 8 of 11
Hub stats look OK to me. BQM confirms the problem and broadly speaking, yes, too many people on video calls (or "essential usage" of Twitch).
In the short term nothing can realistically be done - you tolerate it, or you leave, with all that leaving implies. For some people leaving is the fastest fix and the right thing to do, but before even considering this do your research. VM aren't the only ISP struggling in some areas, but on Openreach if there's a problem it's far more commonly download contention. A competent ISP should know if this applies to your location.
If it is Covid related then in a few months hopefully it goes away. If it doesn't go away post panic-demic, then it's simply down to over-selling by VM of capacity that doesn't exist on your segment.  And the remedy is then again, tolerate with limited prospect of it being fixed, or leave.
monty9845
  • 5
Message 9 of 11
Thank you @Andruser.  One further question - if I upgraded to M200 would I get a better upload speed if there is still general over utilisation or is everyone in the same boat for upload when the network is clogged?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 10 of 11
You could compare it to racing in knee deep mud against an Olympic 100m runner, he would win but the difference wouldn't be as great as racing on a track.
