nologinnames_86
  • 21
Message 1 of 29
upgraded from 200 to 350 speed now slower and inconsistant
I had my broadband package upgraded from 200 to 350mbps (happened 19/12/2020)and the speeds I'm seeing are inconsistent and slower when compared to 200 package, I was getting a consistent 213mbps now I'm ranging from 50mbits to a single one off peak of 263 but the average hits around 192mpbs, the homehub3 has been factory reset twice now, I've run the diagnostic test offered on the virgin media app hasn't sorted anything , its in modem mode and has been for over a year now so I know its not my router causing the issue but this too has been factory reset to ensure there aren't any dodgy settings suddenly causing an issue (which i don't think it is unless its a really unfortunate coincidence of it breaking just as virgin upgraded my package), I've run speed tests directly from the router to ensure its running over gigabit ethernet using speedtest.net as netgear offer this functionality, if anyone has had this problem and knows anything simple to sort it out before i go through customer service ideas would be welcome as i'm not sure i can face going through customer service hoops this close to christmas 🙂
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 2 of 29
Re: upgraded from 200 to 350 speed now slower and inconsistant
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
nologinnames_86
  • 21
Message 3 of 29
11390000005.137256 qam1
2147000000538256 qam2
31550000004.537256 qam3
41630000004.137256 qam4
51710000003.937256 qam5
61790000003.737256 qam6
71870000003.237256 qam7
81950000002.937256 qam8
92030000002.537256 qam9
102110000002.237256 qam10
112190000001.737256 qam11
12227000000137256 qam12
132350000000.436256 qam13
14243000000-0.236256 qam14
15251000000-0.736256 qam15
16259000000-1.236256 qam16
17267000000-0.237256 qam17
18275000000137256 qam18
192830000001.737256 qam19
202910000001.737256 qam20
212990000001.937256 qam21
223070000001.537256 qam22
233150000001.737256 qam23
24323000000237256 qam24
nologinnames_86
  • 21
Message 4 of 29
1Locked37.6297235015006862
2Locked38.6238642191
3Locked37.6207232315795107
4Locked37.6158833901738690
5Locked37.616659128269282
6Locked37.61383940118328
7Locked37.61507159553801
8Locked37.3129779571421
9Locked37.31667720357505
10Locked37.316423382101652
11Locked37.319011776
12Locked37.31814688
13Locked36.691673108605278
14Locked36.616328634907167
15Locked36.6137989335773
16Locked36.616986327726265
17Locked37.394458488506039
18Locked37.315640433116117
19Locked37.312515327674
20Locked37.611377454436
21Locked37.6142494056013
22Locked37.611287357295
23Locked37.62736102227
24Locked37.66347812238
nologinnames_86
  • 21
Message 5 of 29
16030000045.8512064 qam1
24620000044.5512064 qam3
33939995643.3512032 qam4
45370000045.3512064 qam2
1ATDMA0050
2ATDMA0010
3ATDMA0000
4ATDMA0020
nologinnames_86
  • 21
Message 6 of 29
21/12/2020 19:13:6noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/12/2020 19:12:44Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/12/2020 17:20:3noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/12/2020 17:19:53Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/12/2020 16:56:28Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/12/2020 16:56:26Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/12/2020 16:56:24Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/12/2020 16:56:22Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/12/2020 16:56:12Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/12/2020 16:56:4criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/12/2020 16:56:4Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/12/2020 16:56:1Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/12/2020 16:56:1criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/12/2020 16:55:59Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/12/2020 16:55:59critical
nologinnames_86
  • 21
Message 7 of 29
21/12/2020 16:55:58Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/12/2020 16:55:52criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/12/2020 16:55:52Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/12/2020 16:55:50criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/12/2020 16:55:50Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
nologinnames_86
  • 21
Message 8 of 29
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt062+voc-b.cm
SFID5818
Max Traffic Rate402500089
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID5817
Max Traffic Rate38500089
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
nologinnames_86
  • 21
Message 9 of 29
Hi wondering if anyone has had chance to look at this post with any ideas?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 10 of 29
Please post a 'Live Link' to your BQM on here.
