cavalier666
  • 12
Message 1 of 16
upgrade from 350mb to 500mb - no speed change at all
contacted virgin after an hour and 20 min call wait, still no difference. upgraded from 350mb to 500mb and there is no change in the speeds at all.
https://www.speedtest.net/result/10533484366
any ideas why im not getting the 500mb ? everything hard wired ethernet, only use wifi on mobile devices
the speed is tested on a pc with gigabit ethernet ports and cat6 cables
speeds are same, rebooted router multiple times, tried direct and in modem mode to a gaming router, no changes either way
cant see point in paying for 500mb to only get the same 350mb speed
thanks
cavalier666
  • 12
Message 2 of 16
Re: upgrade from 350mb to 500mb - no speed change at all
Aaron2
  • 869
  • 98
  • 162
Well-informed
Message 3 of 16
Upgrades are currently taking 24 hours to go through as part of maintenance on the Virgin side of things, you should see it take affect from tomorrow alongside the new pricing.
Hopefully this helps.
** I work for VirginMedia but all opinions posted here are my own.
cavalier666
  • 12
Message 4 of 16
this was upgraded 1st Dec, still applies almost a week for the upgrade to happen ?
thanks
Aaron2
  • 869
  • 98
  • 162
Well-informed
Message 5 of 16
Not after a week, no, can you tell me what the "max speed" is in the configuration tab?
cavalier666
  • 12
Message 6 of 16
i posted all pics of modem, but they decided not to show (38520000) is in the speed tab
cavalier666
  • 12
Message 7 of 16
just checked again that was upstream tab, its 575000000
SCA1972
  • 5.92K
  • 662
  • 2.02K
Message 8 of 16
@cavalier666 The photos did show, they just need to be approved by mods before they are visible to everyone.
The config does appear to have been upgraded on the hub to M500. You mention testing in modem mode with a gaming router, have you tried modem mode with just your PC? Also worth putting the PC into safe mode to try to rule out any software throttling.
Another possibility is that the PC can’t deliver the extra speed. I have seen users on here upgrade to higher speeds and not get them because their PC’s CPU would max out at 100% usage during speed tests. When you run your tests check on your CPU usage.
Also worth checking Ethernet drivers on PC and trying a new Ethernet cable.
______________________
Scott
My setup: VM TV box, M350 Fibre broadband with Hub 3 in modem mode connected to a Netgear R7000 router. Telewest/VM user since 2001.
cavalier666
  • 12
Message 9 of 16
hi, same speed direct, not the pc, its an intel i9 asus maximus board, with 64gb ram and a 2080 ti
still getting about 353mb this morning, no where near 500, seems lots of errors in the modem config will that cause it ?
SCA1972
  • 5.92K
  • 662
  • 2.02K
Message 10 of 16
Depends on the errors. All logs, even on healthy full speed connections have errors. Copy and paste the log and let us see it.
Scott
