Hi - I understand that speeds will be slower at the moment with more people using the network, but the upload speed is just shocking. I wanted to check there was nothing else wrong. We tried to facetime last night and it was awful. I had to disconnect and use 4G which was far better. We're on a 100mbps connection.
I've done speed tests through the day (hard wired directly to the Hub 3.0). It's been as low as 0.4mbps upload and 16mbps download. Currently it's showing 34.63 down and 1.23 up (on speedtest.net)
PS) I have switched the router on and off multiple times which hasn't helped at all.
EDIT: I tried to upload screenshots, but that's not working.... so here's the raw data. Hopefully you can make sense of it!
Acquired Downstream Channel (Hz) | 298750000 | Locked |
Ranged Upstream Channel (Hz) | 32599848 | Locked |
Provisioning State | Online |
1 | 298750000 | 12.6 | 38 | 256 qam | 21 |
2 | 250750000 | 11.4 | 38 | 256 qam | 15 |
3 | 258750000 | 11.6 | 38 | 256 qam | 16 |
4 | 266750000 | 11.9 | 38 | 256 qam | 17 |
5 | 274750000 | 12.4 | 38 | 256 qam | 18 |
6 | 282750000 | 12.4 | 40 | 256 qam | 19 |
7 | 290750000 | 12.8 | 39 | 256 qam | 20 |
8 | 306750000 | 13.3 | 40 | 256 qam | 22 |
9 | 314750000 | 13 | 40 | 256 qam | 23 |
10 | 322750000 | 13.3 | 38 | 256 qam | 24 |
11 | 330750000 | 12.9 | 38 | 256 qam | 25 |
12 | 378750000 | 13.4 | 38 | 256 qam | 26 |
13 | 386750000 | 12.9 | 38 | 256 qam | 27 |
14 | 394750000 | 13 | 38 | 256 qam | 28 |
15 | 402750000 | 13.1 | 38 | 256 qam | 29 |
16 | 410750000 | 13.4 | 40 | 256 qam | 30 |
17 | 418750000 | 13 | 38 | 256 qam | 31 |
18 | 426750000 | 13.5 | 38 | 256 qam | 32 |
19 | 434750000 | 13.4 | 38 | 256 qam | 33 |
20 | 442750000 | 14 | 38 | 256 qam | 34 |
21 | 450750000 | 14 | 40 | 256 qam | 35 |
22 | 458750000 | 14.3 | 40 | 256 qam | 36 |
23 | 466750000 | 14 | 38 | 256 qam | 37 |
24 | 474750000 | 14.1 | 40 | 256 qam | 38 |
1 | Locked | 38.9 | 25 | 0 |
2 | Locked | 38.9 | 37 | 0 |
3 | Locked | 38.9 | 20 | 0 |
4 | Locked | 38.9 | 32 | 0 |
5 | Locked | 38.9 | 22 | 0 |
6 | Locked | 40.3 | 31 | 0 |
7 | Locked | 39.3 | 26 | 0 |
8 | Locked | 40.3 | 21 | 0 |
9 | Locked | 40.3 | 27 | 0 |
10 | Locked | 38.9 | 40 | 0 |
11 | Locked | 38.9 | 29 | 0 |
12 | Locked | 38.9 | 26 | 0 |
13 | Locked | 38.9 | 50 | 0 |
14 | Locked | 38.9 | 39 | 0 |
15 | Locked | 38.9 | 42 | 0 |
16 | Locked | 40.3 | 47 | 0 |
17 | Locked | 38.9 | 28 | 0 |
18 | Locked | 38.9 | 45 | 0 |
19 | Locked | 38.9 | 43 | 0 |
20 | Locked | 38.9 | 35 | 0 |
21 | Locked | 40.3 | 65 | 0 |
22 | Locked | 40.3 | 43 | 0 |
23 | Locked | 38.9 | 48 | 0 |
24 | Locked | 40.3 | 43 | 0 |
1 | 32599848 | 4.125 | 5120 | 16 qam | 3 |
2 | 53699984 | 4.1 | 5120 | 64 qam | 4 |
3 | 46199990 | 4.1 | 5120 | 16 qam | 1 |
4 | 39400064 | 4.125 | 5120 | 16 qam | 2 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
