fxv300
  • 130
Message 1 of 19
still stuck with a horrible hub 2
oh dear , another 6 months and not been offered any help from VM. This is really frustrating. Have VM not got rid off all the hub 3 routers by now ?  Desperately in need of a decent router (no not HUB 3), HUB 4 has been available since last year but still no sign of anything. I have contacted VM support many times and it is embarrassing (reboot your router), no help whatsoever.
gary_dexter
  • 30.28K
  • 1.88K
  • 4.03K
Message 2 of 19
Re: still stuck with a horrible hub 2
The Hub4 is no better than the Hub3.
Use Modem Mode with your own router.
fxv300
  • 130
Message 3 of 19
yes I have pondered about that, anything you recommend?
Still this is a VM issue, not sure why they insist on using routers with the dreaded PUMA chipset. I heard many comments re HUB4 issues. VM Trying to get the cheapest solution and do not give a to$$ about their paying customers.
DJ_Shadow1966
  • 6.84K
  • 1.31K
  • 1.89K
Message 4 of 19
Hello
To further add the Hub 4 (still puma chipset) is only available to customer who have upgraded to the 1gbps service for all other speeds the Hub 3 is the latest.
Regards Mike
gary_dexter
  • 30.28K
  • 1.88K
  • 4.03K
Message 5 of 19
Well it's a Liberty Global issues really - they issue similiar kit elsewhere as well.
As for recomendations - depends on budget, house size, coverage required etc.
rmboss
  • 21
Message 6 of 19
Its a way to go round it. I just did. I did upgrade to 1gig and then after few days I decided to downgrade to M350 and they let me - and Im sure they will let others - keep the hub 4.
And in my expierence so far its much more better device then hub 3, better range for sure and no issues so far. I only have the hub 4 couple of days  but in that time the hub 3 will already cause me problems.
fxv300
  • 130
Message 7 of 19
I had a look on amazon at some routers (between £100-£200), most have about 15-20% 1-2 star rating with problems.....I'm talking about Netgear, Asus, TP-Link so I'm a bit weary at spending such money for something just as unreliable. What we really need is a DOCSIS 3.1 , have been looking at the Netgear Nighthawk wireless router black Black Dual-Band anyone comment on this device?
  • 22.33K
  • 2.4K
  • 3.98K
Message 8 of 19
If you want to go in with a budget one - see this £40 offer, that has good reviews (see first couple on Amazon) and here.
https://community.virginmedia.com/t5/Networking-and-WiFi/Superhub-3-Issues-resolved/td-p/4251813/pag...
From Amazon
https://www.amazon.co.uk/Tenda-AC10U-1200Mbps-Dual-band-Power-saving/dp/B07C7Y9G96/?th=1
  • 15.9K
  • 687
  • 1.56K
Message 9 of 19
Get mesh setup with a switch if needed.
https://www.amazon.co.uk/ZyXEL-WSR30-EU0201F-MULTY-AC2100-TRI-BAND/dp/B07M92TT95/ref=sr_1_3?dchild=1...
fxv300
  • 130
Message 10 of 19
Comments on Amazon does not fill me with any desire to get one. Thanks anyway.
