Just be aware that if you open a complaint with the likes of CISAS, Virgin will no longer have any contact with you until the final outcome of the complaint.
This is a community forum and we help with internet problems and then a Virgin staff member will step in and arrange an engineers visit or whichever is needed.
If you like you can upload your router stats and set up a BQM and we can take a look to see if there are any problems 🙂
Type 192.168.0.1 or (192.168.100.1 if you have your Hub in Modem mode) into your address bar at the top of your browser
Do NOT log in, just click “Check Router Status” at the bottom of the page. Sometimes the “Check Router Status” is missing, in this case just go ahead and log in and go to Advanced Settings-> Tools-> Network Status.
Please copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs, if you get a yellow warning just click the Post button again.
Do not try to fit everything in one post! You can use more than one post for each item if needed!
If you get a warning when you hit “Post” just hit “Post” again and it should work ok!
Please do not use screenshots
Also can you please setup a Broadband Quality Monitor (BQM) at thinkbroadband.com. Just click on Create a new monitor.
Under your graph you just created Click (Share Live Graph)
Copy the text in the “Direct Link” box and paste it on here
Also, are you testing speeds wired or wireless? If wired are you using a Cat 5e or better Ethernet cable and a PC/Laptop with 1Gbps or better capable network card?
BT Full Fibre 900 FTTP - Asus RT-AX82U to Openreach ONT Box & Asus RT-AX56U with AiMesh setup
