manditey
  • 17
speed
My download speeds have broken since i did a factory reset? We have M350 Wifi so garunteed of 180 download speed.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: speed
What speeds do you get at >> speedtest.net << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Can you Login to the Hub Settings and navigate to the Connected Devices page - what is the reported 'connection speed’ for the ethernet cable connected device you used for the speed test ?
