manditey
  • 17
Message 1 of 11
speed
On m350 package getting these speeds in good distance of wifi?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 11
Re: speed
What speeds do you get at >> speedtest.net << with a direct connection using a Cat 5E or better cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
manditey
  • 17
Message 3 of 11
Re: speed
I can get up to 250+! Was getting good speeds earlier but dropped now!
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 4 of 11
Re: speed
Forget Wi-Fi until the status of the WAN supply can be determined.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 5 of 11
Re: speed
Can you please
manditey
  • 17
Message 6 of 11
Re: speed
12027500002.538256 qam9
22107500002.538256 qam10
32187500002.538256 qam11
42267500002.538256 qam12
52347500002.538256 qam13
62427500002.238256 qam14
7250750000238256 qam15
82587500001.938256 qam16
92667500001.938256 qam17
102747500001.738256 qam18
112827500001.438256 qam19
122907500001.438256 qam20
132987500001.438256 qam21
143067500001.238256 qam22
153147500001.538256 qam23
163227500001.738256 qam24
174027500002.438256 qam25
184107500002.238256 qam26
19418750000238256 qam27
204267500002.238256 qam28
21434750000238256 qam29
224427500001.738256 qam30
234507500001.938256 qam31
244587500001.938256 qam32
1Locked38.650
2Locked38.940
3Locked38.680
4Locked38.940
5Locked38.960
6Locked38.980
7Locked38.960
8Locked38.960
9Locked38.950
10Locked38.680
11Locked38.990
12Locked38.6120
13Locked38.9150
14Locked38.970
15Locked38.9110
16Locked38.600
17Locked38.910
18Locked38.6130
19Locked38.6110
20Locked38.970
21Locked38.960
22Locked38.9110
23Locked38.680
24Locked38.910
manditey
  • 17
Message 7 of 11
Re: speed
Upstream bonded channelsChannel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
13940000930.8512064 qam4
26030000030.5512032 qam1
35370000030.8512032 qam2
44620000031512064 qam3
Upstream bonded channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
3ATDMA0000
4ATDMA0000
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 8 of 11
Re: speed
Your Upstream Power Levels and Modulations are out of spec.
This will need an engineer to put right.
You can either call in (08:00 is the best time) or wait on here for a few days (6 to 7 days average) until one of the VM Forum Staff comes along.
manditey
  • 17
Message 9 of 11
Re: speed
https://www.thinkbroadband.com/broadband/monitoring/quality/share/6e095a9c0e157bdf5b4849bac149ae8894bd916b
manditey
  • 17
Message 10 of 11
Re: speed
Anyway to fix it?
