janiew77
speed test
I just joined last month. Ran a speed test because it all seemed so slow and got
2.86Mbps download 4.16 Mbps upload. My package is M100 - should be
ProductAdvertised Speed*Expected Speed Range**Minimum Guaranteed Download Speed Advertised Speed*Expected Speed Range**
M100108 Mbps108 - 111 Mbps54 Mbps10 Mbps10 Mbps
please can someone advise?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: speed test
Are you testing using Wi-Fi or with a direct connection using a Cat 5E/6 cable between the Hub and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
janiew77
Re: speed test
Hi Mike
it is a wi-fi connection
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: speed test
We need to know whether it is a slow speed from VM to the Hub or slow speed from the Hub to your device.
Can you carry out a couple of speed tests at speedtest.net using a direct connection using a Cat 5E/6 cable between the Hub and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected.
Ensure that the Network Interface Card (NIC) drivers are up to date.
Then post the links to the results on here.
