  • 19
Message 1 of 9
speed problem
Hi I am on M200 and only getting 64 mb when carrying out an OOkla test I find it says Avast as the start point and no virgin.
Tags (1)
  • 19
Message 2 of 9
Re: speed problem
This is what I see
  • 165
  • 22
  • 28
Message 3 of 9
Re: speed problem
When on the ookla app, you can choose the server you wish to connect to by clicking 'Change Server' - pick the server that is closest to you and then retest the speed. Thanks, Marty
If I've helped in any way, please give me Kudos and mark my response as a helpful answer!
Fancy £50 off your bill? Ask me how and you might just get it!
I am a serving Field Technician at Virgin Media however all responses are based on my experiences in the field and my own equipment at home and should be taken as such.
  • 165
  • 22
  • 28
Message 4 of 9
Re: speed problem
are you definitely connected to wifi?
  • 19
Message 5 of 9
Re: speed problem
Yes
I am on it now.
what I get from ookla is
Avast (5.62.43.178)  to Mauritius Telecom London
  • 19
Message 6 of 9
Re: speed problem
Tried changing server on test to no avail there is not Virgin one.
Usually I get virgin to virgin server
  • 1.3K
  • 184
  • 618
Message 7 of 9
Re: speed problem
You have some kind of VPN client running?
Avast's I would assume!
  • 19
Message 8 of 9
Re: speed problem
I have AVG VPN
  • 19
Message 9 of 9
Re: speed problem
Switched off VPN and evrything is
thanks
