je030b5247
  • 18
speed problem (mostly on upload)
Hello,
I have an issue with my speed. The download speed is dropping to anywhere between 100 and the usual 200 (not really an issue) and the upload speed has been dropping to 2-5 and below in the evenings (usual upload is 20). This started on Friday 23rd, but seemed to be fine on 25th, only to be bad again on 26th.
I set up a BQM to take a look and there is a lot of packet loss during the times I experience problems and latency spikes.
24th BQM
25th BQM
26th BQM
Live BQM
I have checked the status page on my-vm and no faults are listed. I ran the test there and it tells me everything is fine. I have restarted the hub (hub 3), reset it to factory via the button and checked all the cables (unplugged and plugged in again). I have tested speeds on 3 computers in the house, all of which are wired and show the same lack of speed.
Here are my router status pages:
133100000013.340256 qam25
218700000011.938256 qam7
31950000001238256 qam8
420300000011.938256 qam9
521100000011.638256 qam10
621900000011.538256 qam11
722700000011.338256 qam12
823500000011.338256 qam13
92430000001138256 qam14
1025100000010.638256 qam15
1125900000010.538256 qam16
1226700000010.938256 qam17
1327500000011.938256 qam18
1428300000012.638256 qam19
1529100000013.140256 qam20
1629900000013.338256 qam21
1730700000013.440256 qam22
1831500000013.140256 qam23
193230000001340256 qam24
2037100000012.840256 qam26
2137900000012.338256 qam27
2238700000011.840256 qam28
2339500000011.840256 qam29
2440300000011.540256 qam30
1Locked40.360
2Locked38.9180
3Locked38.9200
4Locked38.930
5Locked38.940
6Locked38.950
7Locked38.950
8Locked38.960
9Locked38.6120
10Locked38.940
11Locked38.900
12Locked38.900
13Locked38.670
14Locked38.950
15Locked40.350
16Locked38.940
17Locked40.350
18Locked40.350
19Locked40.340
20Locked40.340
21Locked38.940
22Locked40.930
23Locked40.350
24Locked40.370
1462000004.1512064 qam1
2257999274.1512064 qam4
3326000004512064 qam3
4394000564.1512064 qam2
3ATDMA0000
4ATDMA0000
je030b5247
  • 18
Re: speed problem (mostly on upload)
27/10/2020 04:05:0criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/10/2020 04:05:0criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/10/2020 03:52:53noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/10/2020 03:44:12criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/10/2020 03:44:12criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/10/2020 02:45:19criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/10/2020 02:45:19criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/10/2020 02:39:39criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/10/2020 02:39:38criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/10/2020 00:55:29criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/10/2020 00:55:28criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/10/2020 23:43:20criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/10/2020 21:26:40noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/10/2020 17:38:35criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/10/2020 13:38:14Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/10/2020 13:37:19criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/10/2020 13:37:19Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/10/2020 13:37:18criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/10/2020 13:37:1Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/10/2020 13:36:57criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Your Downstream Power Levels are far too high and will need an engineer visit to put them right.
You can either phone in (08:00 is the best time) or wait on here for a few days (6 to 7 days average) until one of the VM Forum Staff comes along.
je030b5247
  • 18
Thank you for the reply. I will wait for a staff member to respond.
Do you know why the power levels only make the connection unstable in the evenings? Or would that be something to ask the engineer?
