  • 50
Message 1 of 11
speed issue
hi guys hoping someone can help i have 2 laptops identical to each other i am getting average speed on one laptop and really slow on the other even if i go back to my old laptops once again there the same laptop i get good speed on one of them but not the other  is there any way to sort it were they both receive a good speed thanks
  • 20.96K
  • 1.14K
  • 2.7K
Message 2 of 11
Re: speed issue
What speeds do they get wired direct to the hub?
  • 50
Message 3 of 11
Re: speed issue
hi gary i cant wire the hub as my laptop dont have Ethernet ports like i say its really strange how 1 laptop get great speed and the other gets really slow speed when they are the same laptop
  • 20.96K
  • 1.14K
  • 2.7K
Message 4 of 11
Re: speed issue
Wireless is a tricky thing to manage.
Have you split the WiFi bands into separate 2.4Ghz and 5Ghz bands?
  • 50
Message 5 of 11
Re: speed issue
Hi Gary i did try that and the speed was good but everyday it kicked me off the internet and would not connect back to the 5g only the 2.4 and i had to rested my router to get re connected so kept it on the duel connection as that works just really slow
  • 20.96K
  • 1.14K
  • 2.7K
Message 6 of 11
Re: speed issue
Have you disabled “smart” WiFi?
  • 50
Message 7 of 11
Re: speed issue
no what is that never heard of that
  • 20.96K
  • 1.14K
  • 2.7K
Message 8 of 11
Re: speed issue
Are you on a Hub3?
  • 50
Message 9 of 11
Re: speed issue
ye its a brand new hub i think i have found my problem my laptop is conneting to 2.4g were the other is connecting to 5g but i dont no how to get mine to connect to the 5g automaticly
  • 20.96K
  • 1.14K
  • 2.7K
Message 10 of 11
Re: speed issue
Disable smart WiFi in the hubs admin page.
Also if you split the WiFi bands you can force it to connect to the 5Ghz broadcast.
