rs1800
  • 6
Message 1 of 5
speed has reduced
My speeds always used to be bang on 200mb at speed.net but have suddenly reduced to about 90Mbps a few days ago. turning on and off didn't do anything. I am in modem only mode.
I will try a full reset and test direct to SH3 if needed but thought I would 1st post power levels if someone could have a look please and let me know ok?
Downstream  DS-1 DS-2 DS-3 DS-4 DS-5 DS-6 DS-7 DS-8
Frequency (Hz)547000000539000000555000000563000000571000000579000000587000000595000000
Lock Status(QAM Lock/FEC Sync/MPEG Lock)LockedLockedLockedLockedLockedLockedLockedLocked
Channel ID1817192021222324
Modulation256QAM256QAM256QAM256QAM256QAM256QAM256QAM256QAM
Symbol Rate (Msym/sec)6.9520006.9520006.9520006.9520006.9520006.9520006.9520006.952000
Interleave DepthI=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
Power Level (dBmV)9.449.479.379.429.439.369.589.60
RxMER (dB)36.3936.1736.3936.3936.8436.8436.8436.84
Pre RS Errors376292362285429734432719420281487389492073523866
Post RS Errors995101199098110079599591008
Upstream  US-1 US-2 US-3 US-4
Channel Type2.02.02.02.0
Channel ID4321
Frequency (Hz)39400000462000005370000060300000
Ranging StatusSuccessSuccessSuccessSuccess
Modulation64QAM64QAM64QAM64QAM
Symbol Rate (Sym/sec)5120000512000051200005120000
Mini-Slot Size4444
Power Level (dBmV)46.0046.0047.5047.50
T1 Timeouts0000
T2 Timeouts0000
T3 Timeouts0000
T4 Timeouts0000
First TimeLast TimePriorityError NumberDescription
25/05/2020 16:02:53 GMT25/05/2020 16:02:53 GMTWarning (5)66050310Auth Success - Web login successful.
25/05/2020 15:57:05 GMT25/05/2020 15:57:05 GMTError (4)68000407TOD established
Time Not EstablishedTime Not EstablishedNotice (6)84000510Downstream Locked Successfully
25/05/2020 15:48:03 GMT25/05/2020 15:48:03 GMTError (4)68000407TOD established
25/05/2020 15:32:44 GMT25/05/2020 15:32:44 GMTError (4)68000407TOD established
24/05/2020 01:30:45 GMT24/05/2020 01:30:45 GMTNotice (6)68010600DHCP Renew - lease parameters tftp file-******** modified
24/05/2020 01:30:45 GMT24/05/2020 01:30:45 GMTError (4)68010400DHCP REBIND WARNING - Field invalid in response
24/05/2020 01:29:51 GMT24/05/2020 01:29:51 GMTError (4)68010100DHCP RENEW sent - No response for IPv4
24/05/2020 01:29:01 GMT24/05/2020 01:29:01 GMTError (4)68010100DHCP RENEW sent - No response for IPv4
24/05/2020 01:27:21 GMT24/05/2020 01:27:21 GMTError (4)68010100DHCP RENEW sent - No response for IPv4
24/05/2020 01:24:01 GMT24/05/2020 01:24:01 GMTError (4)68010100DHCP RENEW sent - No response for IPv4
24/05/2020 01:17:21 GMT24/05/2020 01:17:21 GMTError (4)68010100DHCP RENEW sent - No response for IPv4
24/05/2020 01:04:00 GMT24/05/2020 01:04:00 GMTError (4)68010100DHCP RENEW sent - No response for IPv4
24/05/2020 00:37:18 GMT24/05/2020 00:37:18 GMTError (4)68010100DHCP RENEW sent - No response for IPv4
23/05/2020 23:43:54 GMT23/05/2020 23:43:54 GMTError (4)68010100DHCP RENEW sent - No response for IPv4
23/05/2020 21:57:07 GMT23/05/2020 21:57:07 GMTError (4)68010100DHCP RENEW sent - No response for IPv4
23/05/2020 18:23:34 GMT23/05/2020 18:23:34 GMTError (4)68010100DHCP RENEW sent - No response for IPv4
23/05/2020 11:16:27 GMT23/05/2020 11:16:27 GMTError (4)68010100DHCP RENEW sent - No response for IPv4
rs1800
  • 6
Message 2 of 5
Re: speed has reduced
Forgot to mention, quality test has remained ok.
https://www.thinkbroadband.com/broadband/monitoring/quality/share/436669528ce284ccf299913889195c6e9397767b-19-05-2020
gary_dexter
  • 30.32K
  • 1.88K
  • 4.03K
Message 3 of 5
Over a wired or wireless connection?
rs1800
  • 6
Message 4 of 5
Wired.  As I said above I will reset sh3 and bypass my router/switch etc next but just wanted someone to check levels.
gary_dexter
  • 30.32K
  • 1.88K
  • 4.03K
Message 5 of 5
The levels are fine
