mccjohn
  • 45
Message 1 of 18
speed down 50%
Good morning,
                  A few days ago there were a couple of outages totaling 68minutes. On reconnection my IP address changed, I understand that can happen.
My connection was 500Mbs, received an email advising was being upgraded to 600Mbs. Now the speed is typically 300Mbs. Also on youtube starting to buffer.
Can 150 auto test ran advising problem with hub (hub3) rebooted carried out tested later in the day. No change.
Few days later called 150 again, auto test ran and still advise HUB problem,
Sayed on the phone or 1 hour and 2 minutes only or the system to hang up. Currently 48 minutes into second call
Hub status light appears to be RED, if I'm interpreting correctly means over heating!
Is this a fire risk, Both my wife and I are seventy, in these challenging times we are very reliant on the internet to stay in touch.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 2 of 18
Re: speed down 50%
Are you in Router Mode or Modem Mode ?
In Modem Mode the power light should be magenta.
In Router Mode the power light should be white.
In either Mode the red power light is an indication of over heating and most not be ignored.
Ensure that the Hub is in a well ventilated area and nothing is blocking the vent holes on the sides of the Hub.
If the Hub is in a clear area and is cool to touch it must be replaced.
If the Hub is in a clear area and is hot to touch it must be replaced.
Do not be fobbed off with "if it is cool it will be OK" or "Just blow a fan over it", this is dangerous advice.
When you go out or retire for the night ensure that the Hub is unplugged from the mains.
The only fix is a replacement Hub.
You can either phone in (08:00 is the best time) or wait on here for a few days (6 to 7 days average) until one of the VM Forum Staff comes along.
mccjohn
  • 45
Message 3 of 18
Re: speed down 50%
Thanks for the reply it is in modem mode. Could possibly be magenta. Though took a second opinion and the wife says red.
It is a well ventilated "extract fan" media cupboard. Temperature at extract fan never peaks above 25 degC, temperatures record by Draytek 2927 router.
Does not feel excessively hot!
Spent 1 hour and 3 minutes on hold on 150 help number at which point disconnected.
Ignoring a famous saying repeating an experiment and expecting a differing result is the definition o foolish
I repeated the call to 150 and at 1 hour 3 minutes disconnected.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 4 of 18
Re: speed down 50%
Drop the Hub into Router Mode for a few minutes and check the base light colour.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 5 of 18
Re: speed down 50%
What speeds do you get at >> speedtest.net << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
mccjohn
  • 45
Message 6 of 18
Re: speed down 50%
I have a unit which connects directly to the Dray Tek router. Runs speed test 4 times a day, can also manually initiate test. Prior to change of IP address and outage average speed was above 500Mbs. All cabling is cat6. No other user online.
Dray tek 2927 is rated or 1Gb on wan side
Also logged into hub its running Docsis30 I believe 3.1 is the faster version
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 7 of 18
Re: speed down 50%
Until you speed test the Hub directly you can't prove whether the problem is the WAN supply or the Dray Tek slowing things down.
Which VM Hub are you using ?
mccjohn
  • 45
Message 8 of 18
Re: speed down 50%
Hub 3 on DOCIS 3 I believe 3.1 is the latest version
Tried back to router mode hub 3 no difference in speed.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 9 of 18
Re: speed down 50%
Hub 3 isn't capable of DOCSIS 3.1, only the Hub 4 can use it.
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
mccjohn
  • 45
Message 10 of 18
Re: speed down 50%
Cable Modem Status Item Status Comments
379000000
Locked
Ranged Upstream Channel (Hz)
39400000
Locked
Provisioning State
Online
1379000000640256 qam27
22030000005.840256 qam9
32110000005.940256 qam10
42190000005.940256 qam11
52270000005.538256 qam12
62350000005.340256 qam13
72430000005.340256 qam14
82510000005.140256 qam15
92590000005.440256 qam16
102670000005.640256 qam17
112750000005.640256 qam18
122830000005.640256 qam19
132910000005.840256 qam20
142990000006.538256 qam21
153070000006.540256 qam22
163150000006.640256 qam23
173230000006.640256 qam24
183310000006.540256 qam25
193710000006.440256 qam26
203870000005.940256 qam28
213950000005.640256 qam29
224030000005.340256 qam30
234110000005.340256 qam31
244190000005.540256 qam32
1Locked40.380
2Locked40.33340
3Locked40.3583397
4Locked40.3727464
5Locked38.9472194
6Locked40.33580
7Locked40.3570
8Locked40.3360
9Locked40.3210
10Locked40.3270
11Locked40.3150
12Locked40.3770
13Locked40.91120
14Locked38.9280
15Locked40.9190
16Locked40.9680
17Locked40.3350
18Locked40.31400
19Locked40.3100
20Locked40.380
21Locked40.3120
22Locked40.3170
23Locked40.3220
24Locked40.370
