Leeswin
  • 34
Message 1 of 5
speed data
can someone help me interpret this data
i have a sam knows box that monitors my speed constantly, also I have a the VM500 BB service (i know it will never be that speed), all i want to know is the data below is that good or bad and why you think that?
DATE    AVERAGE  DOWNLOAD (MT)    AVERAGE UPLOAD (MT)    AVERAGE LATENCY       AVERAGE PACKET LOSS
23 Mar   539 Mbps                                       37.0 Mbps                            19.5 ms        0.0 %
24 Mar   573 Mbps                                       37.8 Mbps                           20.0 ms        0.0 %
25 Mar   578 Mbps                                       40.4 Mbps                           20.0 ms        0.0103 %
26 Mar   582 Mbps                                       38.2 Mbps                           20.5 ms        0.00272 %
27 Mar   551 Mbps                                       39.7 Mbps                           20.8 ms        0.00516 %
28 Mar   627 Mbps                                       40.5 Mbps                           22.2 ms        0.00321 %
29 Mar   543 Mbps                                       39.7 Mbps                           20.2 ms        0.00257 %
30 Mar   588 Mbps                                       39.9 Mbps                           15.0 ms        0.0 %
31 Mar   606 Mbps                                       42.0 Mbps                           15.1 ms        0.0 %
01 Apr   534 Mbps                                       41.4 Mbps                           15.1 ms        0.0 %
02 Apr   601 Mbps                                       41.6 Mbps                           15.5 ms        0.0 %
03 Apr   553 Mbps                                       41.9 Mbps                           15.4 ms        0.0 %
04 Apr   625 Mbps                                       42.1 Mbps                           15.6 ms        0.0 %
05 Apr   564 Mbps                                       41.7 Mbps                           15.6 ms        0.0 %
06 Apr   616 Mbps                                       41.6 Mbps                           15.4 ms        0.0 %
07 Apr   643 Mbps                                       42.0 Mbps                           15.4 ms        0.0 %
08 Apr   604 Mbps                                       40.3 Mbps                           15.8 ms        0.0 %
09 Apr   616 Mbps                                       41.8 Mbps                           15.9 ms        0.00253 %
10 Apr   510 Mbps                                       41.9 Mbps                           15.6 ms        0.00245 %
11 Apr   625 Mbps                                        41.7 Mbps                           15.5 ms        0.0 %
Displaying 20 results of 32
Andrew-G
  • 6.12K
  • 1.08K
  • 2.58K
Message 2 of 5
Re: speed data
Those look excellent results, with an average of 583 Mbps.  Some people see a touch more consistency, but there's not that much to complain about on the speed front.   Were you expecting something different?
Or are you encountering any problems with your connection such as latency or disconnection issues?
Kath_F
  • 27.44K
  • 1.05K
  • 2.04K
Message 3 of 5
Re: speed data
Hi Leeswin,
Thanks for your post. I have to agree with Andrew-G. The results are looking really good.
Are you having an issue with anything?
If so pop the details here and we can help look in to things for you.
Speak soon,
Kath_F
Leeswin
  • 34
Message 4 of 5
Re: speed data
All good just want to keep on top of things as I'm not sure the difference between mbps and mbs
Kath_F
  • 27.44K
  • 1.05K
  • 2.04K
Message 5 of 5
Re: speed data
They would be the same things Leeswin 🙂
If you mean the difference between mbps and ms then these are what they stand for:
mbps: megabits per second
ms: milliseconds
If you have any issues then pop back to the Community 🙂
Kath_F
