  • 141
  • 5
  • 9
Up to speed
speed been at half for a week
my 100mb speed been only hitting 45mb for the last 5 days done all the usual stuff reset etc it is wired looking that there is no work going on in erea.this must be your end or the router on its way out 'L84XN.Cheers
  • 4.84K
  • 885
  • 1.28K
Re: speed been at half for a week
ello
Thank for joining in on the forum, we will try the best to get your issue resolved.
How are you doing the speedtest is it either wired or wireless, wired is always the best option. If wired can you please do the following :-
Can you please post your network stats from the hub
Open a Web browser (e.g. Internet Explorer) and enter the address http://192.168.0.1
Note: If you have enabled Modem Mode on your Hub 3.0 you will need to use 192.168.100.1 instead.
Posting the stats by copy and paste will remove all personal information so no breaches.
Do not login but click on where it says "Check Router Stats" and then copy and post from the following 4 tabs, Downstream, Upstream, Configuration and Network logs (if they are pasted then all personal information is * out) and we can check your power level, also while you about that can you please go around and check that all connectors to VM equipment are hand tight. Also while doing this please check for any damage to cable, or un-terminated connection without either coax or a terminator.
Also please run "Check service status" at the top right of this forum and call 0800 561 0061 to check for local issues.
Also one think you can do is too signup at https://www.thinkbroadband.com/broadband/monitoring/quality and setup a broadband quality monitor which will keep an eye on you connection by sending a small amout of data to the hub asking if it still on.
Regards Mike
  • 124
  • 25
  • 25
Please PM me with your account number and area reference and I can take a look at this for you.
Stuart
I am a Virgin Field Technician. All and any advice given is based on my experience in the field or my personal experiences with my own set up at home. If my answer was helpful to you please mark as helpful or consider leaving the post some kudos.
