elviosono
  • 12
Message 1 of 22
speed a joke
just moved my broadband to virgins 100 mbps ? no way not even 50 mbps speed checkers show 28 at best is this grounds for refund or send back its not even close followed the online details to re set check boost set up even slower than before how is this possible my portal even says system boost successful anyone had simialr issues north london
  • 2.87K
  • 214
  • 607
Trouble shooter
Message 2 of 22
Re: speed a joke
Usual request - Post your power levels and network logs from the Hub. We can then comment on the incoming circuit.
Also test using ethernet cable directly connected to the Hub as VM do not accept speed tests using wifi.
elviosono
  • 12
Message 3 of 22
Re: speed a joke
i never bought vm 100 mbps for there ethernet connections so what are you suggesting i only use ethernet ? seems odd should i go around my whole house with a long lead permenatly attached to my devices please let me know if this seems right
SonarUK
  • 516
  • 25
  • 62
Rising star
Message 4 of 22
Re: speed a joke
we are all in the same boat right now with an outage across the UK. none of us can help.
hopefully back up and running within the next few hours
https://twitter.com/SeriousFamily
Vivid 350 | Hub 3 modem mode | Asus RT-AC86U (Stock-Firmware)
gary_dexter
  • 30.27K
  • 1.88K
  • 4.02K
Message 5 of 22
Re: speed a joke
You didn’t buy it for Wifi either since Wifi speeds are not advertised or guaranteed.
elviosono
  • 12
Message 6 of 22
Re: speed a joke
forgot to mention slow speed since day one not just recently or overnight
gary_dexter
  • 30.27K
  • 1.88K
  • 4.02K
Message 7 of 22
Re: speed a joke
So what speeds do you get when wired direct to the hub?
elviosono
  • 12
Message 8 of 22
Re: speed a joke
50
elviosono
  • 12
Message 9 of 22
Re: speed a joke
gary_dexter
  • 30.27K
  • 1.88K
  • 4.02K
Message 10 of 22
Re: speed a joke
Post back a link to that speedtest result please
