malhotra_km
  • 8
Message 1 of 14
slow speed suppose due to Gig1 - 0 Downstream DOCSIS 3.1 Channels
Hello,
I have upgraded three months ago and still not able to get more than 500 speed in best circumstances. Spoken to virgin media multiple times but nothing sorted.
Looking for help.
Screenshot 2022-01-04 at 16.24.34.pngScreenshot 2022-01-04 at 16.24.55.pngScreenshot 2022-01-04 at 16.25.05.png
  • 33.76K
  • 3.31K
  • 6.42K
Message 2 of 14
Re: slow speed suppose due to Gig1 - 0 Downstream DOCSIS 3.1 Channels
Whilst waiting for the images....
Your ~500Mbps.... is that over wifi or on an ethernet cable connected computer or laptop?
If wifi then you will never get much more than that as the Hub4 is only wifi5. You will need Wifi6 equipment to get more speed over wifi.
https://www.increasebroadbandspeed.co.uk/realistic-speeds-wi-fi-5-and-wi-fi-6
malhotra_km
  • 8
Message 3 of 14
Thanks @jbrennand, its on wired connection.
Here is the DOCSIS channels I get. not sure the issue is due to only getting DOCSIS 3.0 channels?
Channel Overview Downstream Upstream
DOCSIS 3.0 channels
31
4
DOCSIS 3.1 channels
1
0
  • 33.76K
  • 3.31K
  • 6.42K
Message 4 of 14
I cant read you images - can you post the data as text as below - someone more familiar with the Hub4 can then comment. There may be other reasons why you only get ~500. Are you in modem mode?...  with your router applying some QoS to ration the bandwidth. Other equipment concurrently connected - can, and does affect speeds ... So disconnect all other ethernet connected and wifi devices.  Also test at https://speedtest.samknows.com/ - if speeds are still low - boot the computer/laptop into safe+networking mode and test speeds again
____________________
Just copy/paste the normal “Formatted Text” (not images) 3 FULL sets of data onto here – 2 pages from the Downstream, 2 from the Upstream, & also the Network Logs page. Don't worry too much about the formatting it can be easily read & DON’T include personal data or MAC addresses - blank them out - if you copy/paste the data, the board software will do this for you (you may need to click the "submit" button again. If character limits are “exceeded” - just do two posts if you exceed the character limits.
malhotra_km
  • 8
Message 5 of 14
3.0 Downstream channels
25331000000-0.90000240.946209QAM25625
10211000000-1.00000040.366287QAM25610
11219000000-1.29999940.946209QAM25611
12227000000-1.40000238.983261QAM25612
13235000000-1.70000138.983261QAM25613
14243000000-1.59999840.366287QAM25614
15251000000-1.90000238.983261QAM25615
16259000000-1.40000240.366287QAM25616
17267000000-1.59999838.983261QAM25617
18275000000-1.50000038.983261QAM25618
19283000000-1.00000040.366287QAM25619
20291000000-0.29999940.366287QAM25620
212990000000.40000240.366287QAM25621
223070000000.00000040.366287QAM25622
23315000000-0.40000240.946209QAM25623
24323000000-1.00000040.366287QAM25624
26339000000-0.59999840.366287QAM25626
27347000000-0.29999940.366287QAM25627
28355000000-0.50000040.366287QAM25628
29363000000-0.29999940.366287QAM25629
30371000000-0.40000240.366287QAM25630
31379000000-0.70000140.366287QAM25631
32387000000-0.70000140.366287QAM25632
33395000000-0.79999940.366287QAM25633
34403000000-0.90000240.366287QAM25634
35411000000-1.00000040.366287QAM25635
36419000000-1.00000040.366287QAM25636
37427000000-1.00000040.366287QAM25637
38435000000-0.90000240.366287QAM25638
39443000000-0.90000240.366287QAM25639
40451000000-1.09999840.946209QAM25640
25Locked40.94620930
10Locked40.36628730
11Locked40.94620920
12Locked38.98326120
13Locked38.98326130
14Locked40.36628720
15Locked38.98326170
16Locked40.36628700
17Locked38.98326150
18Locked38.98326150
19Locked40.36628700
20Locked40.36628710
21Locked40.366287130
22Locked40.36628720
23Locked40.94620950
24Locked40.36628730
26Locked40.36628720
27Locked40.36628760
28Locked40.36628750
29Locked40.36628740
30Locked40.36628700
31Locked40.36628710
32Locked40.36628760
33Locked40.36628740
34Locked40.36628720
35Locked40.36628710
36Locked40.36628720
37Locked40.36628750
38Locked40.36628740
39Locked40.36628720
40Locked40.94620920
3.1 Downstream channels
41964K1880QAM4096728
41Locked42-0.835208437550
malhotra_km
  • 8
Message 6 of 14
3.0 Upstream channels
13940000049.5205995120 KSym/sec64QAM7
24620000049.7705995120 KSym/sec64QAM3
36030000050.5205995120 KSym/sec64QAM1
45370000050.0205995120 KSym/sec64QAM2
1US_TYPE_STDMA0020
2US_TYPE_STDMA0010
3US_TYPE_STDMA0010
4US_TYPE_STDMA0010
malhotra_km
  • 8
Message 7 of 14
Time
Priority
Description
Sat Oct 9 09:04:41 2021
5
MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=***;CMTS-MAC=***;CM-QOS=1.1;CM-VER=3.1;
Sat Oct 9 13:27:31 2021
3
No Ranging Response received - T3 time-out;CM-MAC=***;CMTS-MAC=***;CM-QOS=1.1;CM-VER=3.1;
Tue Oct 12 03:04:19 2021
4
DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=***;CMTS-MAC=***;CM-QOS=1.1;CM-VER=3.1;
Fri Oct 15 15:03:41 2021
5
Fri Oct 15 20:21:07 2021
3
Fri Oct 15 21:48:34 2021
6
CM-STATUS message sent. Event Type Code: 24; Chan ID: 41; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=***;CMTS-MAC=***;CM-QOS=1.1;CM-VER=3.1;
Sat Oct 16 06:10:45 2021
3
Mon Oct 18 23:30:09 2021
4
Sun Oct 24 16:26:46 2021
3
Mon Oct 25 22:13:30 2021
4
Fri Oct 29 09:04:48 2021
5
Sun Oct 31 02:39:06 2021
4
Sun Oct 31 14:29:05 2021
3
Tue Nov 2 18:26:23 2021
4
Wed Nov 3 07:35:58 2021
3
Sat Nov 6 06:26:23 2021
4
Tue Nov 9 00:38:27 2021
3
Tue Nov 9 15:57:14 2021
6
Tue Nov 9 18:26:24 2021
4
Tue Nov 9 21:59:22 2021
3
Sat Nov 13 06:26:24 2021
4
Mon Nov 15 00:39:41 2021
3
Tue Nov 16 18:26:24 2021
4
Wed Nov 17 08:01:04 2021
3
Sat Nov 20 06:26:24 2021
4
Sat Nov 20 16:31:51 2021
3
Mon Nov 22 17:29:06 2021
5
Thu Jan 1 00:01:23 1970
3
Mon Nov 22 18:09:06 2021
5
Wed Nov 24 23:48:45 2021
3
Thu Nov 25 00:17:48 2021
4
Tue Nov 30 09:50:36 2021
3
Wed Dec 1 09:52:17 2021
4
Sun Dec 5 03:38:08 2021
3
Mon Dec 6 04:17:30 2021
6
CM-STATUS message sent. Event Type Code: 5; Chan ID: 22; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=***;CMTS-MAC=***;CM-QOS=1.1;CM-VER=3.1;
Wed Dec 8 09:52:17 2021
4
Wed Dec 15 08:37:12 2021
5
Wed Dec 15 08:37:23 2021
5
RCS Partial Service;CM-MAC=***;CMTS-MAC=***;CM-QOS=1.1;CM-VER=3.1;
Wed Dec 15 08:37:41 2021
6
CM-STATUS message sent. Event Type Code: 4; Chan ID: 41; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=***;CMTS-MAC=***;CM-QOS=1.1;CM-VER=3.1;
Thu Dec 16 10:30:31 2021
3
Fri Dec 17 00:20:13 2021
5
Fri Dec 17 06:18:59 2021
3
Sun Dec 19 17:51:17 2021
4
Sun Dec 19 22:52:25 2021
3
jem101
  • 4.26K
  • 437
  • 1.82K
Community elder
Message 8 of 14
@malhotra_km the channel allocation is right, for the gig one tier, there should be 31 DOCSIS 3.0 channels and one 3.1 channel, and that’s on the downstream, the upstream is four 3.0 channels. Upstream power is worryingly close the upper limit but if it is stable then that’s not necessarily an issue. There is nothing in the logs to indicate any issue, although they seem to end around 19th December so possibly something else is going on which the logs aren’t reporting.
Personally I’d do a complete factory (pinhole) reset of the hub and then run a Speedtest and also see what the logs show.
malhotra_km
  • 8
Message 9 of 14
reset it,
here is latest logs
Thu Jan 1 00:01:26 19703No Ranging Response received - T3 time-out;CM-MAC=***;CMTS-MAC=***;CM-QOS=1.1;CM-VER=3.1;
Tue Jan 4 17:20:59 20225MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=***;CMTS-MAC=***;CM-QOS=1.1;CM-VER=3.1;
malhotra_km
  • 8
Message 10 of 14
just to add, no improvement on speed.
