tellme
  • 33
Message 1 of 29
slow speed due to congestion - how to fix?
For more than a week I am getting 10up 0.3 down on my 50Mb contract during day time (8am-6pm).
In the evening it's back close to the contractual speed.
My router is fine - I run all the test suggested in this forum and last 4 days monitoring are ok BQM
This is clearly a congestion issue - too many VM customers in my street. How to fix this issue?
DJ_Shadow1966
  • 6.65K
  • 1.28K
  • 1.81K
Message 2 of 29
Re: slow speed due to congestion - how to fix?
Hello
I am afraid that a fix isn't going to be easy as VM will have to add extra capacity to the area and would mean re-segmentation of the local network, with extra equipment need and can take several mths or longer depending on the costs.
Regards Mike
conman33158
  • 853
  • 80
  • 120
Superfast
Message 3 of 29
@tellme wrote:
Your BQM does not show any congestion but rather slight packet loss. Copy and paste your router stats as this might show something amiss.
tellme
  • 33
Message 4 of 29
Thanks ..
I am not an expert - is it correct that my chart show no material packet losses or other issues but the speed is constrained by VM?
It looks like my contract is 50mb but VM limits my speed to 17mb during peak times. Is this correct?
My next-door neighboor has VM 100Mb and he is getting 93Mb whilst I am getting 17mb with my 50mb contract. We run the speed test at the same time with the same app.
My modem data seems fine (see earlier post post )
Many thanks
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 5 of 29
What speeds do you get at >>  SamKnows << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Then immediately after …
Login to the Hub Settings and navigate to the Connected Devices page - what is the reported 'connection speed’ for the ethernet cable connected device you used for the speed test ?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 6 of 29
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
Please do not use screen shots.
Copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs onto here, if you get a yellow / straw box warning click the Post button again.
Use one post for each tab if you wish.
conman33158
  • 853
  • 80
  • 120
Superfast
Message 7 of 29
All I can tell you is your BQM does not show over usage or it would be showing up on your BQM.
tellme
  • 33
Message 8 of 29
Hi Robbo, are you an algo?
I have share all the data in here Link as per your post , but the guru didn't show...
tellme
  • 33
Message 9 of 29
hi con man
I was wondering how the thinkbroadband site can show if my area is oversubscribed? I think my connection speed is managed down by VM - not sure how thinkbroadband can tell..
carl_pearce
  • 4.75K
  • 405
  • 713
Superstar
Message 10 of 29
The BQM does show packet loss, however the ping response (Latency) is unbelievably good for a VM connection:
You don't have a second connection on the same device you setup the BQM from?
