beano2
  • 30
slow speed again
well that didn't last long new box fitted everything going nicely but speed gone again fed up
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: slow speed again
How are you connecting your device, Wi-Fi or ethernet cable ?
What speed do you get using a direct connection using a Cat 5E/6 cable between the Hub and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
It can be difficult diagnosing problems without some basic information.
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Then
Can you please
