I recently upgraded to gig1 internet but the speeds are so slow, wifi on my phone is lucky if it makes 250 download and thats me right beside the hub 4, but the real problem is the ethernet. I run everything on ethernet instead of wifi, always have and have never had a problem. The problem being is anything plugged into the back of the hub does not go above 100 apart from the VM 360 box which i get 230 download speed, but that is nowhere near what i should be getting, I have unplugged everything and just plugged my pc into the back of the hub and it just makes 97 down, the pc is capable of 1 gig and i have enabled that in the properties section of the ethernet adapter.
i have tried various speed tests including "samknows" which says the speed to the hub is 1144 but to the pc is 97. When i access the hub it says various equipment connected by ethernet is receiving 1000mbps or is capable of receiving it but it is not going above 100 infact alot of equipment is alot lower. The cables connecting the equipment are all decent not cheap rubbish and all my equipment is maximum 2 years old so it aint old tech.
i have tried various cables including cat 5e, cat 6 and nothing will give me the speed i pay for, i do realise that i will never get 1000mbps on wifi but on ethernet i should be getting close to it.
I phoned up today and the lady i spoke too was more interested in the wifi problem rather than the ethernet . And the wifi problem aint changed any after being told they will run tests
to be honest i am within my cooling off period and if this is the speed i will get then i think i will be cancelling too, i have read a few posts online about ethernet problems with the hub 4 that goes on for months or does not get resolved, thats hardly a way to keep customers happy.
Stuart
