philneal
  • 8
Message 1 of 10
slow download speed
I'm a new customer with the 100mbps package, I am getting download speeds fluctuating  between 5mb and 1mb, this is slower than expected.
Can anyone help with anything that I can do??
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 10
Re: slow download speed
Which Hub do you have ?
What speeds do you get at >> speedtest.net << with a direct connection using a Cat 5E or better cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
philneal
  • 8
Message 3 of 10
Hi I'm using the smart hub 3
philneal
  • 8
Message 4 of 10
can anyone help
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 5 of 10
philneal
  • 8
Message 6 of 10
19.06mbps but I am paying for 100mbps
[removed]
[MOD EDIT: Personal and private information has been removed from this post. Please do not post personal or private information in your public posts. Please review the Forum Guidelines]
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 7 of 10
Have you got a different ethernet cable you can test with.
philneal
  • 8
Message 8 of 10
ill test tomorrow, im getting same results via wifi on my mobile next to the router.
philneal
  • 8
Message 9 of 10
Still same speed, shall I try the factory reset button ?
Or do I need to contact virgin ?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 10 of 10
Give a reset a go.
DO NOT DO THIS if the password on the base of the Hub is not legible or missing.
Disconnect all unneeded ethernet cables from the rear of the Hub.
With the Hub Powered on use a paperclip or similar (I use a mobile phone SIM Slot tool) and do a pinhole reset.
DO NOT reboot the hub but allow it 5 to 10 minutes for it to boot itself up.
Once a steady white and no other lights are illuminated check your system again.
