@pbritton wrote:
Thanks for the reply; sorry for the delay in responding. I've done as you suggest and recorded a download speed of 155 Mb/s. So the problem is clearly with my Wifi but what can I do about it?
You need to be connected to 5Ghz for better speeds or else you have a problem with your wifi card. Also try a reset on the Hub first. Hold in the pinhole at the rear of the router for at least 50 seconds and then release (the lights will flash while holding in the pinhole reset button after about 10-15 seconds) then allow 5 minutes for the router to reboot and re-sync the connection.
Please ensure that your WiFi network password is still readable on the Hub sticker before you do this or that you at least have a copy of your original network password.
Also try splitting the wifi bands
Type http://192.168.0.1 into your URL address bar on your browser and login into the Hub with your chosen password or use the settings password on the Hubs sticker on the bottom of the Hub and set up the Hub with a new password. Then go to Advanced>Wireless>Smart Wi-Fi and tick the disable “channel optimisation” box and save settings. Then go to Advanced>Wireless>Security and rename the 2.4Ghz and 5Ghz network SSID's. Change them to whatever you like, for example JohnsVirgin_2 and JohnVirgin_5. You can keep the same wi-fi passwords or use one of your choosing, then click apply settings and restart the Hub. Your two wi-fi networks will now be separated and you can select whichever network you want to connect too, for example the JohnsVirgin_2 (2Ghz) or JohnsVirgin_5 (5Ghz). The 2Ghz one has a greater range but has a slower speed and the 5Ghz one has less range but faster speeds. Be aware that some older devices will only see the 2.4Ghz SSID but most modern devices will come with 5Ghz capability.
Also please be aware that all your previously connected wireless devices will need to be connected again to your new SSID's with you new passwords or your old password if you decided to keep them.
BT Full Fibre 900 FTTP - Asus RT-AX82U to Openreach ONT Box & Asus RT-AX56U with AiMesh setup
