harley555
  • 8
slow broadband 6mbps part1
11870000000.538256 qam7
21950000000.237256 qam8
3203000000-0.237256 qam9
4211000000-0.238256 qam10
5219000000-0.235256 qam11
6227000000-0.538256 qam12
7235000000-0.740256 qam13
8243000000-138256 qam14
9251000000-140256 qam15
10259000000-1.240256 qam16
11267000000-1.240256 qam17
12275000000-1.440256 qam18
13283000000-1.740256 qam19
14291000000-1.738256 qam20
15299000000-1.738256 qam21
16307000000-2.240256 qam22
17315000000-2.238256 qam23
18323000000-2.438256 qam24
19443000000-4.738256 qam25
20451000000-4.438256 qam26
21459000000-4.738256 qam27
22467000000-4.538256 qam28
23475000000-4.738256 qam29
24483000000-537256 qam30
1Locked38.61836274
2Locked37.62424309
3Locked37.32084440
4Locked38.91344310
5Locked35.720490130
6Locked38.9110027
7Locked40.3112047
8Locked38.91355173
9Locked40.3154322
10Locked40.3191426
11Locked40.320740
12Locked40.3247312
13Locked40.9312311
14Locked38.9543515
15Locked38.672530
16Locked40.3111320
17Locked38.9146250
18Locked38.9186330
19Locked38.67327220
20Locked38.67923040
21Locked38.69328440
22Locked38.611426110
23Locked38.615667050
24Locked37.618499750
1394000684.825512064 qam2
2462000004.875512064 qam1
3326000244.7512064 qam3
4258001124.5512032 qam4
3ATDMA0000
4ATDMA000
0
harley555
  • 8
Re: slow broadband 6mbps part1
part2.
04/04/2020 21:02:34noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/04/2020 08:25:51ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/04/2020 08:14:33ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/04/2020 08:02:3criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/04/2020 07:30:15noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/04/2020 05:46:27ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/03/2020 19:03:41criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/03/2020 07:39:51ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/03/2020 06:59:47ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/03/2020 08:52:21Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/03/2020 12:33:5ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/03/2020 10:44:27ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/03/2020 01:02:4criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/03/2020 12:11:11noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:42Warning!ToD request sent - No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/03/2020 07:03:21ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/03/2020 21:38:20criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/03/2020 15:33:51noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/03/2020 16:30:31criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/03/2020 20:00:46ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
om_spencer
  • 64
Hi harley555,
Your power levels are on the low end and you have a build up of RS errors. Do you have an attenuater fitted to your hub it looks red with a number like 6db on it.
Thank you
harley555
  • 8
I don't think so there is nothing on the back.
harley555
  • 8
Re: slow broadband 6mbps part1 switch effect
Hi people,
I have a netgear Fs605 switch which i plug my pc into among other devices. I plugged my pc in directly without the switch and got 200mbps .I guess i need a better switch?. Any advice?
om_spencer
  • 64
Yes you need gigabite lan switch which is better with your current switch your limited to 100mbs. Most network switchs are 1gb lan.
Thank you
