Anon333
  • 13
Message 1 of 10
slow and inconsistent broadband speed
For the past few weeks, I have been getting very slow broadband speeds. At best, download speed has been ~30mbps and at worst, 0.14mbps which is close to dial-up speed and not at all acceptable, as this renders browsing the web unbearable having an impact upon my productivity as I am currently working from home (I have an IT job!). My upload speed has been between ~0.5-10mbps. What I should however be getting is 200mbps down and 20 up.
I have tried calling Virgin Media, unfortunately no agent is available and the connection drops shortly after the reset.
One strange thing that occurs is during certain times during evenings I will be getting ~40mbps down and ~10mbps up, however as soon as I turn youtube on the whole internet becomes dial-up speed. Then I turn off youtube and speeds are bearable (but not what I am paying for). I was under the impression that throttling ended years ago, however it seems the opposite?
I would appreciate if this can be looked into ASAP as this has been an ongoing issue and isn't acceptable.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 10
Re: slow and inconsistent broadband speed
I take it you are connecting to the Hub using Wi-Fi ?
Then
Can you please
When the page appears DO NOT LOG IN but click ‘Check Router Status’.
Copy and paste the contents of the Downstream, Upstream and Network Log tabs onto here, if you get a yellow warning click the Post button again.
dinth
  • 47
  • 45
Dialled in
Message 3 of 10
Hey Anon333.
Is there any chance you're using an app or service which extensively uses UDP connections (like torrents, VPNs, VOIP, Microsoft Teams, BBC iPlayer)?
Anon333
  • 13
Message 4 of 10
Hi, no i am not just youtube
Anon333
  • 13
Message 5 of 10
Thank you very much for the response.
Please see below for the BQM:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/e551f3ce121437d0214cb3566798f58378...
Anon333
  • 13
Message 6 of 10
11630000007.440256 qam4
21390000006.840256 qam1
3147000000740256 qam2
41550000007.440256 qam3
51710000007.540256 qam5
6179000000840256 qam6
71870000008.540256 qam7
81950000008.540256 qam8
92030000008.340256 qam9
102110000008.340256 qam10
112190000008.540256 qam11
122270000008.440256 qam12
13235000000840256 qam13
14243000000840256 qam14
152510000008.440256 qam15
162590000008.340256 qam16
17267000000840256 qam17
18275000000840256 qam18
192830000008.140256 qam19
202910000008.340256 qam20
212990000008.440256 qam21
223070000008.340256 qam22
233150000008.440256 qam23
243230000008.340256 qam24
1Locked40.370
2Locked40.3870
3Locked40.387615
4Locked40.9180
5Locked40.3230
6Locked40.9130
7Locked40.930
8Locked40.970
9Locked40.3120
10Locked40.9110
11Locked40.980
12Locked40.3100
13Locked40.9100
14Locked40.3100
15Locked40.9100
16Locked40.980
17Locked40.380
18Locked40.3170
19Locked40.970
20Locked40.980
21Locked40.3120
22Locked40.3200
23Locked40.9210
24Locked40.9140
Anon333
  • 13
Message 7 of 10
1537000124.725512064 qam2
2393999964.475512064 qam4
3461999864.575512064 qam3
4603000264.875512064 qam1
3ATDMA0000
4ATDMA0000
Anon333
  • 13
Message 8 of 10
27/08/2020 04:45:11criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/08/2020 00:04:13noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/08/2020 00:04:13ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/08/2020 23:32:55criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/08/2020 23:32:45Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/08/2020 23:29:18criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/08/2020 23:28:27Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/08/2020 23:28:24criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/08/2020 17:09:49Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/08/2020 17:09:49criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/08/2020 17:09:48Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/08/2020 17:09:42Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/08/2020 17:09:42criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/08/2020 17:09:41Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/08/2020 17:09:41criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/08/2020 16:19:52criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/08/2020 16:17:51Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/08/2020 16:17:51criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/08/2020 16:17:13criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
liamparry
Message 9 of 10
Hi Anon333, did you get this resolved? I am having inconsistent speeds also. I'm on M350 but randomly get 10-50mbs. I am also seeing a lot of these critical and warning messages but don't know what any of it means.
Natalie_L
  • 2.64K
  • 119
  • 216
Message 10 of 10
Hi liamparry,
Welcome and thank you for posting.
I am very sorry to hear you are experiencing issues with the broadband service.
Are you able to confirm if the speed is dropping on both wired and wireless connections? If so, can you please run a speed test for both connections and post the results?
Thank you
Nat
