manchestermusic
  • 6
Message 1 of 9
slow 500mb speed
ime Priority Description
16/01/2021 13:36:56noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/01/2021 18:43:40criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/01/2021 02:33:39noticeSW download Successful - Via NMS
15/01/2021 02:31:9noticeSW Download INIT - Via NMS
15/01/2021 00:39:20criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/01/2021 06:49:52noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt053+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/01/2021 06:49:52ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/01/2021 17:29:35noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/01/2021 15:09:25criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/01/2021 11:35:59noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt053+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/01/2021 11:35:59ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/01/2021 02:18:16criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/01/2021 13:04:4noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt053+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/01/2021 13:04:4ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/01/2021 13:02:44criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/01/2021 01:04:4noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt053+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/01/2021 01:04:4ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/12/2020 16:53:47criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/12/2020 13:04:4noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt053+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/12/2020 13:04:4ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Message 2 of 9
Re: slow 500mb speed
What speeds do you get at >>  SamKnows << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Message 3 of 9
A bit more information is required, please post the following ...
Please do this before posting the Hub Data
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Message 4 of 9
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
Please do not use screen shots.
Copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs onto here, if you get a yellow / straw box warning click the Post button again.
Use one post for each tab if you wish.
manchestermusic
  • 6
Message 5 of 9
Refresh data
1 60300000 40.5 5120 64 qam 9
2 39399954 40.5 5120 64 qam 12
3 46200000 40.5 5120 64 qam 11
4 53700000 40.5 5120 64 qam 10
1 ATDMA 0 0 1 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 0 0
manchestermusic
  • 6
Message 6 of 9
Refresh data
1 202750000 8 40 256 qam 9
2 138750000 10 38 256 qam 1
3 146750000 9.3 40 256 qam 2
4 154750000 9.1 40 256 qam 3
5 162750000 9 40 256 qam 4
6 170750000 8.8 40 256 qam 5
7 178750000 8.5 40 256 qam 6
8 186750000 8.1 40 256 qam 7
9 194750000 7.9 40 256 qam 8
10 210750000 7.9 40 256 qam 10
11 218750000 8.1 40 256 qam 11
12 226750000 7.8 38 256 qam 12
13 234750000 7.5 38 256 qam 13
14 242750000 7.4 40 256 qam 14
15 250750000 7.1 40 256 qam 15
16 258750000 7.4 38 256 qam 16
17 266750000 7.4 40 256 qam 17
18 274750000 7 40 256 qam 18
19 282750000 7.4 40 256 qam 19
20 290750000 6.8 38 256 qam 20
21 298750000 6.8 40 256 qam 21
22 306750000 6.5 40 256 qam 22
23 314750000 6.1 38 256 qam 23
24 322750000 6.4 38 256 qam 24
1 Locked 40.3 244 0
2 Locked 38.6 123 0
3 Locked 40.3 96 0
4 Locked 40.3 79 0
5 Locked 40.9 86 0
6 Locked 40.3 114 0
7 Locked 40.3 162 0
8 Locked 40.3 145 0
9 Locked 40.9 272 0
10 Locked 40.3 538 0
11 Locked 40.3 584 0
12 Locked 38.9 915 0
13 Locked 38.9 1025 0
14 Locked 40.3 834 0
15 Locked 40.3 1286 0
16 Locked 38.9 1970 0
17 Locked 40.3 1843 0
18 Locked 40.3 2089 0
19 Locked 40.3 1764 0
20 Locked 38.9 3119 0
21 Locked 40.3 3462 0
22 Locked 40.3 4188 0
23 Locked 38.9 5359 0
24 Locked 38.9 7337 0
manchestermusic
  • 6
Message 7 of 9
hannel Frequency (Hz) Power (dBmV) SNR (dB) Modulation Channel ID
1202750000840256 qam9
21387500001038256 qam1
31467500009.340256 qam2
41547500009.140256 qam3
5162750000940256 qam4
61707500008.840256 qam5
71787500008.540256 qam6
81867500008.140256 qam7
91947500007.940256 qam8
102107500007.940256 qam10
112187500008.140256 qam11
122267500007.838256 qam12
132347500007.538256 qam13
142427500007.440256 qam14
152507500007.140256 qam15
162587500007.438256 qam16
172667500007.440256 qam17
18274750000740256 qam18
192827500007.440256 qam19
202907500006.838256 qam20
212987500006.840256 qam21
223067500006.540256 qam22
233147500006.138256 qam23
243227500006.438256 qam24
1Locked40.32440
2Locked38.61230
3Locked40.3960
4Locked40.3790
5Locked40.9860
6Locked40.31140
7Locked40.31620
8Locked40.31450
9Locked40.92720
10Locked40.35380
11Locked40.35840
12Locked38.99150
13Locked38.910250
14Locked40.38340
15Locked40.312860
16Locked38.919700
17Locked40.318430
18Locked40.320890
19Locked40.317640
20Locked38.931190
21Locked40.334620
22Locked40.341880
23Locked38.953590
24Locked38.973370
manchestermusic
  • 6
Message 8 of 9
Router status
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
a69834ncxv9873254k;fg87dsfd;k
SFID25225
Max Traffic Rate575000000
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID25224
Max Traffic Rate38520000
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling TypeBestEffort
manchestermusic
  • 6
Message 9 of 9
Network LogTime Priority Description
