gingerbones
  • 39
Message 1 of 11
running at less than a quarter of what it should
I have tried reseting and power on and off several times but i'm only getting at best 45mbs instead of the 200mbs i am paying for .
I'm using a cat 6 ethernet cable from the router to the pc and it was working fine  so its either my router or something at your end
  • 6.08K
  • 511
  • 1.57K
Message 2 of 11
Re: running at less than a quarter of what it should
Check with Area faults on 0800 561 0061 or if you have a VM landline 150 firstly.
Also post the Hubs power levels and network log for comment.   Setup a BQM here to monitor your circuit.  www.thinkbroadband,com/ping
You could also try a 60 second factory reset on the Hub, it's something VM will ask you to do anyway.
Remove any ethernet cables from the Hub and hold the pinhole reset switch for 60 seconds. Do NOT reboot the Hub, just let it do it's thing. Note you will need the passwords from the bottom of the Hub afterwards, so make sure they are legible.
gingerbones
  • 39
Message 3 of 11
However its made no difference I did some tests and it said that there was network interference !!!
I have also taken at how the router is doing and I have a whole host of wifi issues mostly weak signal.
I think it might be my router however I'm getting mixed messages because depending on where i run the test from eg from router or through the website I am getting conflicting answers one says there's no problem the other says there's an issue.
Meanwhile i'm still only getting 43mbps not the 200mbps that I should be.
  • 33.55K
  • 3.29K
  • 6.37K
Message 4 of 11
Can you test speeds like this first.
_______________________________
As you expect >100Mbps then connect a 1GB enabled computer/laptop, with up to date drivers, via a NEW and working Cat5e/6a ethernet cable, directly to the Hub which you have put into “modem mode”
(https://www.virginmedia.com/help/virgin-media-hub-modem-mode ).
This ensures that NO other devices are connected
Test speeds at https://speedtest.samknows.com/ - try on 2 different browsers.
If they are still low – boot your device into Windows safe+networking mode - to disable any potentially interfering software - and try again.
There are many posts on here (I have a list of ~30!) where QoS software, unknown/flaky software, old network card drivers, corrupted browsers, bad cables or other connected devices are limiting speeds on tests.
Report back what that gets.
gingerbones
  • 39
Message 5 of 11
thanks for the tips, however they made no difference
I've tried 4 different cables all cat 6 2 different pc's  the only link is the router and cabling to the house.
Everything was ok until 2 days ago.
no software updates on either pc I will keep plugging away. But i'm convinced its a cabling or router problem
here's what my router is saying I have no idea what it means but i'm sure someone will.
Refresh data
Cable Modem Status
Item
Status
Comments
299000000
Locked
Ranged Upstream Channel (Hz)
60299964
Locked
Provisioning State
Online
Refresh data
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
299000000
2.7
31
256 qam
21
2
187000000
0
25
256 qam
7
3
195000000
0.2
25
256 qam
8
4
203000000
1.4
25
256 qam
9
5
211000000
1.9
26
256 qam
10
6
219000000
2.2
26
256 qam
11
7
227000000
2.5
26
256 qam
12
8
235000000
2.7
29
256 qam
13
9
243000000
2.9
30
256 qam
14
10
251000000
2.5
30
256 qam
15
11
259000000
2.4
30
256 qam
16
12
267000000
2.9
30
256 qam
17
13
275000000
2.5
30
256 qam
18
14
283000000
2.4
30
256 qam
19
15
291000000
2.5
30
256 qam
20
16
307000000
2.5
31
256 qam
22
17
315000000
2.2
31
256 qam
23
18
323000000
2
31
256 qam
24
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
31.6
7184456
22
2
Locked
25.1
143549
29050717
3
Locked
25.3
2462859
82665564
4
Locked
25.8
30003093
55015003
5
Locked
26.9
64941136
19701753
6
Locked
26.9
68869124
14881324
7
Locked
26.6
56168903
28655313
8
Locked
29
55427025
59
9
Locked
30.5
11535028
24
10
Locked
30.6
9326682
0
11
Locked
30.5
11039253
0
12
Locked
30.5
12824566
4
13
Locked
30.1
18696236
0
14
Locked
30.1
20189981
0
15
Locked
30.6
19403870
0
16
Locked
31.9
4672557
17
17
Locked
31.6
7017571
0
18
Locked
31.3
6590958
5
Refresh data
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
60299964
51
5120
64 qam
1
2
39400036
51
5120
64 qam
4
3
46200036
51
5120
64 qam
3
4
53700041
50.5
5120
64 qam
2
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
0
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
0
0
Refresh data
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
dsfd;kfoA,.iyewrkldJKDHSU
SFID
31637
Max Traffic Rate
230000061
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
31638
Max Traffic Rate
22000061
Max Traffic Burst
42600
Min Traffic Rate
0
Max Concatenated Burst
42600
Scheduling Type
BestEffort
Refresh data
Time
Priority
Description
26/11/2021 11:37:23
Warning!
RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/11/2021 11:37:23
Warning!
Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/11/2021 11:36:49
Warning!
26/11/2021 11:36:46
Warning!
26/11/2021 11:36:11
Warning!
26/11/2021 11:36:10
Warning!
26/11/2021 11:35:45
Warning!
26/11/2021 11:35:45
Warning!
26/11/2021 11:35:32
Warning!
26/11/2021 11:35:32
Warning!
26/11/2021 11:35:1
Warning!
26/11/2021 11:34:59
Warning!
26/11/2021 11:34:48
Warning!
26/11/2021 11:34:48
Warning!
26/11/2021 11:34:34
Warning!
26/11/2021 11:34:33
Warning!
26/11/2021 11:34:18
Warning!
26/11/2021 11:34:17
Warning!
26/11/2021 11:33:15
Warning!
26/11/2021 11:33:15
Warning!
  • 33.55K
  • 3.29K
  • 6.37K
Message 6 of 11
Yes thats dreadful ! Low SNR's, high Up power levels and RS errors are ominous. First job - reset all to 0 - can you do this...
__________________________________________________
Switch the Hub off and unplug it from the mains supply for five minutes. Whilst it's off, do a quick check that all of your coax cable connections are in nice and "finger" tight - at the Hub and wall box and also at any connectors etc. Ensure there are no “unterminated cable loose ends.
Disconnect all the connections and reconnect to be sure. Also check that the internal wiring is ok with no kinking or chaffing, check that all looks good with the outside cabling and wall box (no “staples, etc.,) piercing the cables.. Then switch the Hub back on and leave ~5 minutes
When all done, check back in the settings and ensure that the RS error counts and T3 errors have all reset to 0. Then check every hour or so to see if they start reappearing - they shouldn't. If they do (particularly the postRS and T3 ones) you have a problem (noise) that only a Tech visit will sort.
Post the data back up to see if anything has improved
gingerbones
  • 39
Message 7 of 11
Hi John,
Many thanks for the advice, you may be o to something. I found the cable into the router was very slightly loose.
I removed and resecured everything ,checked the router again and the rs errors are at 0 i've ran the speedtest again and its back at 200 yay!
I will monitor it in a little while and keep an eye on it .
The connection was only very slightly loose but maybe thats all it needed. I will post again later with an update.
Thanks again
jem101
  • 4.21K
  • 432
  • 1.8K
Community elder
Message 8 of 11
That is indeed, all that is needed to destroy a connection, it’s one of the reasons why VM don’t allow, and we always advise against, DIY cabling, extending or reducing the coax cable. You only need one slightly dodgy joint, a piece of cable which ‘looks’ like the same but actually has the wrong characteristics - and all bets are off.
Lee_R
  • 6.22K
  • 287
  • 649
Message 9 of 11
Hi @gingerbones thanks for posting and welcome back to our community.
Thanks for coming back to confirm your issue appears to be resolved.  Remember if you ever need assistance in the future, our fantastic community and forum team are always willing to lend a hand.
Lee_R
gingerbones
  • 39
Message 10 of 11
Sadly Lee it has not been resolved
I have someone coming tomorrow to take a look at it. It would appear it is either the router or a cable issue.
So far in the last 2 days my router has rebooted itself 8 times without any warning .
Its a total pain and is causing absoute carnage while trying to work online.
