spankthemunkey1
  • 165
  • 20
Up to speed
Message 1 of 5
rebates
Hi, I know i am waiting for ( field engineers ) to see what is happening with my 350 meg broadband totally failing yet again ( has been for years now but nobody else usable to go with ),  just seeing all the other people non stop complaining about their abysmal speeds, yes i know everyone is using the internet But dont you think that virgin media should give people a rebate ?.
  When we are paying for a 350 meg service but only receiving between zero and 20 meg, this is a joke. Virgin tv box is next to useless and just switches off and constant buffering at times, the continual lag on tv programs is well terrible.
All this from the company that are supposed to be going down the route of putting in 10gig fibre, its fine if you live on a street or an area that does not suffer over subscription like we have for the last 10 years. They are quick enough to charge a late payment fee if you are a day late in paying your bill. but they cant sort out the services.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 2 of 5
Re: rebates
What speeds do you get at >> speedtest.net << with a direct connection using a Cat 5E or better cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 3 of 5
Re: rebates
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 4 of 5
Re: rebates
Can you please
spankthemunkey1
  • 165
  • 20
Up to speed
Message 5 of 5
Re: rebates
just search my recent post, 350meg really. that will show you the BQM charts. here is todays
