kawsar11499
  • 45
Message 1 of 7
ps5 lag
since i got the hub4 my gaming has been lagging, on a few games not just one, here are my router stats from a laptop ethernet:
3.0 Downstream channels
253307500001.59999840.366287QAM25625
11387500003.00000038.605377QAM2561
21467500003.00000038.983261QAM2562
31547500002.59999838.983261QAM2563
41627500002.00000038.605377QAM2564
51707500001.70000138.983261QAM2565
61787500001.20000138.605377QAM2566
71867500001.20000138.983261QAM2567
81947500001.40000238.983261QAM2568
92027500001.50000038.983261QAM2569
102107500001.20000138.983261QAM25610
112187500001.09999840.366287QAM25611
122267500001.29999938.983261QAM25612
132347500001.00000038.983261QAM25613
142427500000.70000138.605377QAM25614
152507500001.00000040.366287QAM25615
162587500000.50000038.983261QAM25616
17266750000-0.09999838.983261QAM25617
182747500001.00000038.983261QAM25618
192827500001.40000240.366287QAM25619
202907500001.50000040.366287QAM25620
212987500001.90000238.983261QAM25621
223067500002.20000140.946209QAM25622
233147500001.70000138.983261QAM25623
243227500001.70000140.366287QAM25624
263387500001.59999840.366287QAM25626
273467500001.79999940.946209QAM25627
283547500001.70000140.366287QAM25628
293627500001.70000140.366287QAM25629
303707500001.50000040.366287QAM25630
313787500000.90000240.366287QAM25631
25Locked40.36628700
1Locked38.60537700
2Locked38.98326100
3Locked38.98326100
4Locked38.60537700
5Locked38.98326100
6Locked38.60537700
7Locked38.98326100
8Locked38.98326100
9Locked38.98326100
10Locked38.98326100
11Locked40.36628700
12Locked38.98326100
13Locked38.98326100
14Locked38.60537700
15Locked40.36628700
16Locked38.98326100
17Locked38.98326100
18Locked38.98326100
19Locked40.36628700
20Locked40.36628700
21Locked38.98326100
22Locked40.94620900
23Locked38.98326100
24Locked40.36628700
26Locked40.36628700
27Locked40.94620900
28Locked40.36628700
29Locked40.36628700
30Locked40.36628700
31Locked40.36628700
3.1 Downstream channelsChannel Channel Width (MHz) FFT Type Number of Active Subcarriers Modulation (Active Profile) First Active Subcarrier (Hz)
33944K1840QAM4096424
3.1 Downstream channelsChannel ID Lock Status RxMER Data (dB) PLC Power (dBmV) Correcteds (Active Profile) Uncorrectables (Active Profile)
33Locked42-0.1772757830
kawsar11499
  • 45
Message 2 of 7
Re: ps5 lag
3.0 Upstream channels
13260000046.7705995120 KSym/sec64QAM7
24620000046.7705995120 KSym/sec64QAM5
32580000046.7705995120 KSym/sec64QAM8
43940000046.7705995120 KSym/sec64QAM6
1US_TYPE_STDMA0000
2US_TYPE_STDMA0000
3US_TYPE_STDMA0000
4US_TYPE_STDMA0000
kawsar11499
  • 45
Message 3 of 7
Re: ps5 lag
General Configuration
Network access
true
Maximum Number of CPEs
1
Baseline Privacy
true
DOCSIS Mode
3.1
Config file
cmreg-vmdg640-bbt057+voc-b.cm
SFID
33030
Max Traffic Rate
117000047
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
33029
Max Traffic Rate
10500047
Max Traffic Burst
16320
Min Traffic Rate
0
Max Concatenated Burst
16320
Scheduling Type
bestEffort
kawsar11499
  • 45
Message 4 of 7
Re: ps5 lag
Thu Jan 1 00:01:20 19703No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue Aug 17 12:30:16 20215MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue Aug 17 12:33:22 20216SW Download INIT - Via Config file cmreg-vmdg640-bbt057+voc-b.cm
Tue Aug 17 12:34:48 20216SW download Successful - Via Config file
Tue Aug 17 12:37:46 20215MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue Aug 17 13:03:35 20214DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
  • 30.78K
  • 3.04K
  • 5.83K
Message 5 of 7
Re: ps5 lag
Hub stats look ok to me but someone more familiar with a Hub4 should comment.
Are you gaming over wifi or over ethernet? If ethernet have you changed to a new cable?
Also, in the meantime... If you haven’t already, set up a free and secure “Broadband Quality Monitor” to continually monitor the state of your connection and record any true network dropouts , latency issues, packet drops, etc - it will thus allow you to differentiate between those and simple wifi dropouts. It does it 24/7/365 and it keeps a visual record of any/all of your network disconnections, useful data to have to match to the Network logs (in your Hub settings) and also in discussions with VM - note it will take a few hours to start seeing a sensible picture - post up the “link” to the “share live graph” (as per instructions on the TB website) when it starts to develop.
kawsar11499
  • 45
Message 6 of 7
Re: ps5 lag
Hi i am gaming over wifi, i havent set up my booster (power line adaptor) with the new hub and left it on, could that be the reason why it was lagging?
  • 30.78K
  • 3.04K
  • 5.83K
Message 7 of 7
Re: ps5 lag
Gaming over wifi is notoriously flaky. My lad uses powerline adapters and 2 short ethernet cables to connect his Pc and consoles to the Hub via them - has never had a single issue
