jaberwok
  • 42
Message 1 of 27
possible intermittent fault ?
Download speeds have seemed slow for several weeks. I tested today between 13:00 and 15:00 and got results varying between 67 and 160 Mbps.
M200:  Windows 7 Ultimate: Super Hub 3
Software Version "V1.01.35"
Hardware Version 3.11
Lots of errors - Error Number Error Description
                        84020200       Lost MDD Timeout
traceroute to bbc.co.uk (151.101.0.81), 30 hops max, 64 byte packets
01 10.53.37.117 <10.000ms <0.000ms <10.000ms
02 86.28.83.57 <10.000ms <10.000ms <10.000ms
03 * * *
04 * * *
05 62.254.84.66 <10.000ms <20.001ms <10.000ms
06 157.52.127.10 <20.000ms <20.001ms <20.000ms
07 151.101.0.81 <10.000ms * <10.000ms
Traceroute complete.
What does this mean?
  • 30.87K
  • 3.05K
  • 5.85K
Message 2 of 27
Re: possible intermittent fault ?
Test it on an ethernet cable connection directly into the Hub.
If still slow put Hub3 into modem mode and test again
If still slow boot it into safe+networking mode (still in modem mode) and test again
Report back what that gets
jaberwok
  • 42
Message 3 of 27
Thank you.
MY PCs are connected by ethernet; WiFi is a non-issue for me.
Why put it in modem mode? I would have to move my connections around.
  • 30.87K
  • 3.05K
  • 5.85K
Message 4 of 27
Modem mode just ensures that no other devices can be connected over wifi and ethernet - these can and do affect/attenuate speeds. Or just pull the plugs on all other ethernet connections and disable wifi in the Hub settings.
jaberwok
  • 42
Message 5 of 27
Thanks, that seems sensible BUT after swapping cables and changing to modem mode, I had zero connectivity.
After a hub factory reset and a computer restart, I now have internet again on one pc (of course) but I still cannot access the hub to change it back to router mode.
Average download speeds, as checked this afternoon, have increased from 36 Mbps to 38.5 Mbps - hardly outstanding on an M200 contract.
I have insisted that Virgin now replace this hub (that's another story).
jaberwok
  • 42
Message 6 of 27
Okay. After another reset, I am now back in router mode.
Download speeds are back to around 44 Mbps.
  • 30.87K
  • 3.05K
  • 5.85K
Message 7 of 27
Disconnect any other ethernet cables from the Hub, in the Hub settings. switch the wifi off and then boot into safe + networking mode, use a new Cat5e/6/7 ethernet cable and test speeds at
https://speedtest.samknows.com
try on 2 different browsers.
Reportt back what that produces
Eeeps
  • 907
  • 57
  • 158
Well-informed
Message 8 of 27
Are those the software and hardware version number of the HUB3? Where do you see those because they are rather unusual.
jaberwok
  • 42
Message 9 of 27
My mistake, it's a SH2. Numbers as reported by the hub.
  • 30.87K
  • 3.05K
  • 5.85K
Message 10 of 27
Did you test speeds as I suggested in message 7?
If so what was the outcome?
